Aligning 3 point plate - vector cross product useful?
In summary: Your Name]In summary, the question is about how to level a plate with a fixed front foot and two adjustable back feet. The solution involves using a combination of rotational and translational movements to align the x and y axes to 0g, with the ratio of turn amount for each back foot being the same for all axes. The acceleration due to gravity in the z-axis can be used to calculate the turn amount for the back feet in the x and y axes.
thomas49th
655
Hello,
I have a plate that needs levelling. I can only twist the back 2 feet threaded feet, while the single front foot is fixed, as in the diagram:
As mentioned above I can only TWIST the back two feet (separately or together) causing the plate to tilt around the fixed front foot.
Given an initial setup where one back foot is higher than another and given that I know the acceleretation due to g in each axis (x,y and z), how do I find the ratio of turn amount of each backfoot to get the system level. That is how many turns on one back foot to the other backfoot is required to bring the system to acceleration:
X axis 0g
Y axis 0g
Z axis 1g
One way of aligning to to align the axis axis first by adjusting the 2 back feet until x-axis is 0, then moving them both the same amount to get y to 0g as well (by moving them by the same amount the acceleration of x-axis is not varied)
I thought perhaps the cross product would help, but it's just a guess
Thanks
Thomas
Dear Thomas,
Thank you for your question. In order to level the plate, you will need to use a combination of rotational and translational movements. The first step would be to adjust the back feet until the x-axis is at 0g. This can be achieved by using a rotational movement of the back feet, while keeping the front foot fixed.
Once the x-axis is at 0g, you can then use translational movement of both back feet in the same direction to bring the y-axis to 0g. This can be achieved by adjusting the back feet by the same amount, as you mentioned.
To find the ratio of turn amount for each back foot, you can use the fact that the acceleration due to gravity (g) is constant in all axes. This means that the ratio of turn amount for each back foot will be the same for all axes. Therefore, if you know the acceleration due to gravity in the z-axis (1g), you can use this to calculate the turn amount for the back feet in the x and y axes.
I hope this helps. Let me know if you have any further questions.
Related to Aligning 3 point plate - vector cross product useful?
1. What is the purpose of aligning a 3 point plate?
The purpose of aligning a 3 point plate is to ensure accurate and precise measurements can be taken. This is especially important in scientific experiments and investigations where even the slightest error can affect the results.
2. How is a 3 point plate aligned?
A 3 point plate is aligned by using a vector cross product. This involves finding the cross product of two vectors that are perpendicular to the plate. By aligning the plate with these vectors, it can be ensured that it is perfectly level and perpendicular to the reference frame.
3. Why is the vector cross product useful for aligning a 3 point plate?
The vector cross product is useful for aligning a 3 point plate because it allows for precise and accurate alignment. It takes into account the direction and magnitude of the vectors, ensuring that the plate is aligned in all three dimensions.
4. Can a 3 point plate be aligned without using the vector cross product?
Technically, yes, a 3 point plate can be aligned without using the vector cross product. However, this method may not be as accurate and may require additional measurements and adjustments to ensure the plate is aligned correctly.
5. How often should a 3 point plate be aligned?
The frequency of aligning a 3 point plate will depend on the specific experiment or investigation being conducted. In general, it is recommended to align the plate before each use or at regular intervals to ensure accurate and reliable results.
