Autocorrelation function of a Wiener process & Poisson process
In summary, the third and fourth step of the homework statement are both applications of the Tower Law.
JohanL
158
3. The Attempt at a Solution [/B]
Can anyone possibly explain step 3 and 4 in this solution?
Step 3 looks like an application of the Tower Law or 'Law of Total Expectation' (see link). It's a very useful law and well worth spending the time to familiarise yourself with it!
The fourth step is just an application of the given autocorrelation function to the expression inside the outer expectation.
Likes JohanL
Sometimes (at least when one is starting out) it is better to be less abstract and more explicit. So, let's be explicit.
Assume ##s < t##, so ##N(t) \geq N(s)## (because of the possible arrivals between ##s## and ##t##). Thus
[tex] \begin{array}{rcl}R_X(s,t) &= & \sum_{j=0}^{\infty} \sum_{k=0}^{\infty} P(N(s)=j, N(t) = j+k) E[W(j) W(j+k)] \\
&= &\sigma^2 \sum_j \sum_k P(N(s)=j) P(N(t) = j+k|N(s)=j) \min(j,j+k)
\end{array}
[/tex]
Of course, ##\min(j,j+k) = j## and we also have ##P(N(t) = j+k | N(s) = j) = P(N(t-s) = k)##, by stationarity and independent increments of the Poisson process. Now the rest is easy.
Of course, if ##t < s## we can just interchange the roles of ##s## and ##t## in the argument.
Likes JohanL
\end{array}
[/tex]
I had only seen the tower law used in connection with martingales, and defined in connection with martingales, and the law of total expectation have i ofc used but only in what they call the special case on the wiki-page. Did not know it was a more general case. Ty!
Related to Autocorrelation function of a Wiener process & Poisson process
What is an Autocorrelation Function?
An autocorrelation function is a mathematical tool used in statistics to measure the correlation between a time series and a lagged version of itself. It is often used to identify patterns or relationships between data points over time.
How is Autocorrelation Function Calculated for a Wiener Process?
The autocorrelation function for a Wiener process is calculated by taking the covariance between two points in time and dividing it by the product of their individual variances. This process is repeated for different time lags to create a series of autocorrelation values.
What is a Wiener Process?
A Wiener process, also known as Brownian motion, is a mathematical model used to describe the random movement of particles. It is often used in finance, physics, and other fields to model the behavior of systems that undergo random fluctuations.
How is Autocorrelation Function Calculated for a Poisson Process?
The autocorrelation function for a Poisson process is calculated by taking the covariance between two time intervals and dividing it by the product of their individual means. This process is repeated for different time lags to create a series of autocorrelation values.
What is a Poisson Process?
A Poisson process is a mathematical model used to describe the occurrence of events over time. It is often used in fields such as queuing theory and reliability analysis to model the arrival of customers or failures of a system.
