Binomial expansion of relativistic formula
In summary, the speed of electrons from a high energy accelerator can be calculated using the relativistic formula (v/c = (1-(1/4V^2))^0.5) and the binomial series can be used to find (1-v/c) in terms of V, with the correct expression being (1-v/c = (1/8V^2) - (3/128V^4) + (5/1024V^6) - (35/32768V^8) + ...).
seboastien
53
The speed v of electrons from a high energy accelerator is very near the speed of light c. Given the voltage V of the accelerator, calculate the ratio v/c. The relativistic formulafor this calculation is (see relevant equations)
Use the binomial series to find (1-v/c) in terms of V
v/c = (1-(4v^2)^-1)^0.5 = (approx) [1- (1/8V^2) + (3/128V^4) - (15/3072V^6)]
therefore;
1-v/c= (1/8V^2) - (3/128V^4) + (15/3072V^6) = 1.25x10^(-17)
V^2 - 2.34x10^(-20)V^4 + 4.88x10^(-24)V^6
Thank you for your post! Your approach using the binomial series is correct. However, there are a few minor errors in your final expression for (1-v/c). The correct expression is:
You can see that the pattern is that the numerator alternates between 1 and -1, and the denominator increases by a power of 2 each term. Also, the first term in your expression should be (1/8V^2) instead of (1/4V^2).
Overall, your work shows a good understanding of the concept and a good use of the binomial series. Keep up the good work!
Related to Binomial expansion of relativistic formula
1. What is the binomial expansion of the relativistic formula?
The binomial expansion of the relativistic formula is a mathematical technique used to approximate the value of the relativistic formula for high values of the speed of light. It is derived from the binomial theorem and allows for a simpler calculation of the formula in cases where the speed of light is approaching its maximum value.
2. Why is the binomial expansion used for the relativistic formula?
The binomial expansion is used for the relativistic formula because it allows for a more efficient and accurate calculation when the speed of light is approaching its maximum value. It also helps to simplify the complex mathematical expressions involved in the formula.
3. How is the binomial expansion applied to the relativistic formula?
To apply the binomial expansion to the relativistic formula, the formula is first expressed in terms of the speed of light (c). Then, the binomial theorem is used to expand the formula into a series of terms, with each term containing a higher power of c. The terms are then simplified and combined to give a more accurate approximation of the original formula.
4. What are the limitations of the binomial expansion for the relativistic formula?
While the binomial expansion is a useful tool for approximating the relativistic formula, it does have its limitations. It is most accurate for values of c that are close to its maximum value, and becomes less accurate as c decreases. Additionally, it is only an approximation and may not provide an exact solution for the formula.
5. How does the binomial expansion affect the interpretation of the relativistic formula?
The binomial expansion does not change the interpretation of the relativistic formula, but rather provides a more simplified and efficient way to calculate it for certain cases. It allows for a better understanding of the behavior of the formula for high values of c and can be used to make predictions or estimations in practical applications of the formula.
