Biomechanics question: Need help with this lab
In summary: Therefore, the force from the lower leg mass is F_leg = (5.684 kg)(9.8 m/s^2)(sin15°)(0.15 m)/(0.4 m) = 88.8 N.To keep the knee at 45 degrees, the sum of forces acting on the knee joint must be equal to 0. Therefore, we can set up the equation:F_person + F_ankle + F_leg = 0960.4 N + 196 N + 88.8 N =
kae3210
A person is sitting and extending the knee at an angle of 45 degrees.
The mass of the person is 98 kg, the lower leg length is 44 cm and the location of the weight is 40 cm with respect to the knee.
Assumptions:
The mass of the lower leg and foot is 5.8% of total body mass. Assume this mass acts at distance of 15 cm from the knee joint.
• The knee extensors insert at an angle of 15º to the long axis of the leg and that this attachment is 4.5 cm from the knee joint center.
Assume the ankle weight that is on the ankle is 20kg.
• What is knee extensor force required to keep the knee at 45º?
I don't even know. I'm guessing that it's these.
Sum of moments = 0
Sum of forces = 0
I drew a free body diagram but that's as far as I get...
Thank you for your post. I would like to help you find the solution to your problem.
First, let's define the variables we will be using:
- Mass of the person (m) = 98 kg
- Mass of lower leg and foot (m_leg) = 5.8% of total body mass = 5.684 kg
- Length of lower leg (l) = 44 cm
- Distance of weight from knee joint (d) = 40 cm
- Distance of lower leg mass from knee joint (d_leg) = 15 cm
- Angle of knee extension (θ) = 45 degrees
- Angle of knee extensor insertion (α) = 15 degrees
- Distance of knee extensor insertion from knee joint (d_ext) = 4.5 cm
- Weight on ankle (W) = 20 kg
Now, let's consider the forces acting on the knee joint. There are two main forces: the force from the weight of the person and the force from the weight on the ankle. The force from the weight of the person can be calculated using the formula F = mg, where g is the acceleration due to gravity (9.8 m/s^2). Therefore, the force from the weight of the person is F_person = (98 kg)(9.8 m/s^2) = 960.4 N.
Next, let's consider the force from the weight on the ankle. This force acts at a distance of 44 cm from the knee joint, and it can be calculated using the formula F = Wd/l, where W is the weight on the ankle, d is the distance from the knee joint, and l is the length of the lower leg. Therefore, the force from the weight on the ankle is F_ankle = (20 kg)(44 cm)/(44 cm) = 20 kg x 9.8 m/s^2 = 196 N.
Now, we need to consider the force from the lower leg mass. This force acts at a distance of 15 cm from the knee joint and at an angle of 15 degrees to the long axis of the leg. To calculate this force, we can use the formula F = m_leg x g x sin(α) x (d_leg/d), where m_leg is the mass of the lower leg and foot, g is the acceleration due to gravity,
1. What is biomechanics?
Biomechanics is the study of the mechanics of living organisms, including humans. It involves understanding how the body moves, how forces act on it, and how it responds to those forces.
2. What is the importance of studying biomechanics?
Studying biomechanics can help us understand how the body functions and moves, which can aid in the prevention and treatment of injuries, as well as improving athletic performance. It can also provide insights into how animals and humans evolved and adapted to their environments.
3. How is biomechanics applied in sports?
Biomechanics is used in sports to analyze and improve techniques and movements, prevent injuries, and design equipment such as shoes and sports gear. It can also be used to assess an athlete's performance and identify areas for improvement.
4. What are some common tools and methods used in biomechanics research?
Some common tools and methods used in biomechanics research include motion capture systems, force plates, electromyography (EMG), and computer simulations. These tools help researchers collect and analyze data on movement patterns, forces, and muscle activity.
5. How can understanding biomechanics benefit healthcare?
Understanding biomechanics can help healthcare professionals diagnose and treat injuries and conditions related to movement and posture. It can also aid in the development of rehabilitation and assistive devices for individuals with physical impairments. Additionally, knowledge of biomechanics can improve surgical techniques and outcomes.
  • General Math
