Bolt preloading vs. temperature
In summary, bolt preloading is the process of applying tension to a bolt in order to create a clamping force between two or more parts. Temperature can affect bolt preloading by causing a decrease in tension and thermal cycling. Bolt preloading and bolt torque are two different methods used for securing bolts, with preloading being considered more accurate and reliable. Determining the appropriate bolt preloading for a specific application involves calculations based on material properties and consulting engineering guidelines. Other factors besides temperature, such as material properties, surface condition, and tightening method, can also affect bolt preloading and should be taken into consideration.
danohl
Hi,
Using a gasket in a bolt connection; does the thickness of the gasket influence the preload of the bolt when the temperature changes?
Since the thermal expansion is length/length/temperature the thickness does not influence, what am I missing here? My current assumption is this:
ΔF_bolt = ΔT(α_gasket*E_gasket*A_gasket - α_bolt*E_bolt*A_bolt)
What I have is a steel bolt connection with a gasket of a different material (i.e. stiffness and thermal expansion is different). The bolt is preloaded and the subject to a temperature increase.
Cheers,
Daniel
Yes, the thickness of the gasket can influence the preload of the bolt when the temperature changes. This is because the thermal expansion of the gasket material will be different than the thermal expansion of the bolt material. As the gasket expands at a different rate than the bolt, the gap between the two will change. This leads to an increase or decrease in preload, depending on the relative expansion of the two materials. Additionally, the stiffness of the gasket material will affect how much the gap changes with temperature. So yes, the thickness of the gasket can influence the preload of the bolt when the temperature changes.
Related to Bolt preloading vs. temperature
1. What is bolt preloading?
Bolt preloading is the process of applying a specific amount of tension to a bolt in order to create a clamping force between two or more parts. This clamping force helps to secure the parts together and prevent loosening or separation.
2. How does temperature affect bolt preloading?
Temperature can affect bolt preloading in two ways. First, as temperature increases, metal expands, which can cause a decrease in bolt preloading. Second, temperature changes can lead to thermal cycling, which can cause bolts to lose their preload over time.
3. What is the difference between bolt preloading and bolt torque?
Bolt preloading and bolt torque are two different methods used to secure bolts. Bolt preloading involves applying tension to a bolt, while bolt torque involves tightening a bolt to a specific torque value. Preloading is considered to be a more accurate and reliable method for achieving the desired clamping force.
4. How can I determine the appropriate bolt preloading for a specific application?
The appropriate bolt preloading for a specific application can be determined through calculations based on the material properties of the bolt and the parts being joined, as well as the desired clamping force. It is important to consult engineering guidelines and standards to ensure proper bolt preloading for safety and performance.
5. Are there any factors besides temperature that can affect bolt preloading?
Yes, besides temperature, there are several other factors that can affect bolt preloading, including the material properties of the bolt and the parts being joined, the surface condition of the bolt and the parts, and the method of tightening. It is important to consider all of these factors when determining the appropriate bolt preloading for an application.
  • Mechanical Engineering
  • General Engineering
  • Materials and Chemical Engineering
