eyust
- 1
I have written this problem myself to present to my professor. He teaches HVAC and Electrical for the department of Construction Management. Some of the problems and solutions we do in class are inconsistent with the material I was taught in physics. He really appreciates my criticism and I actually found a few errors in the material he has been teaching for the past 15 years. I am, however, a bit confused when it comes to electric motors.
In this problem you are given a simple circuit with a voltage of 120v. It has three resistors in series. R1, R2, and R3. R1 and R2 is your line resistance. R3 is http://www.grainger.com/Grainger/DAYTON-Direct-Drive-Blower-Motor-3LU91?Pid=search" .
Given:
Vt across entire circuit is = 120v
R1 = R2 = .25 ohms
Single phase A/C circut
PF= 1
Motor Specs:
1 HP
Voltage: 115v
Full load Amps: 14.7
Hz: 60
Single Phase motor
Efficiency: High
Calculate total Voltage drop due to R1 and R2 when the motor is at a constant full load
2. Homework Equations
R=V/I
Rs= R1+ R2 + R3 +...
I=V/T
Use R=V/I to find the resistance applied to the circuit when the motor is at full load.
115/14.7= 7.823 ohms
Find total R
.25 + .25 + 7.823 = 8.323 ohms = Rt
***Will this always be the resistance applied by the motor at full load if only voltage across the motor changes? Based on the spec of the motor and properties of A/C motors is this a correct assumption?***
Use Rt and Vt to calculate It
It = Vt/Rt
120/8.323= 14.418 amps = total current
Use Total Current, R1 and R2 to calculate voltage drop due to line resistance.
R1 + R2 = Rline
Rline = .25 + .25 = .5ohms
Voltage drop = It * Rline
Voltage drop = 14.418 * .5 = 7.209V
Given:
R1 = R2 = .25 ohms
PF= 1
Motor Specs:
1 HP
Voltage: 115v
Hz: 60
Single Phase motor
Efficiency: High
R=V/I
I=V/T
Find total R
It = Vt/Rt
R1 + R2 = Rline
