Complex eigenvalue proof
In summary: What can you say about ##Y_1, Y_2## if this is true?In summary, we are trying to show that Y1 and Y2, with real entries, are linearly independent when A is a matrix with a complex eigenvalue λ=α+iβ. We start by expressing AY0=λY0 in terms of real numbers and vectors. Then, assuming Y1 and Y2 are linearly dependent, we get two equations by setting the real and imaginary parts of the resulting equation equal to each other. By plugging in the assumption that Y1=kY2, we can see that this would result in Y1 and Y2 being equal to 0, which contradicts the fact that they
Dusty912
149
Suppose the matrix A with real entries has the complex eigenvalue λ=α+iβ, β does not equal 0. Let Y0 be an eigenvector for λ and write Y0=Y1 +iY2 , where Y1 =(x1, y1) and Y2 =(x2, y2) have real entries. Show that Y1 and Y2 are linearly independent.
[Hint: Suppose they are not linearly independent. Then (x2, y2)=k(x1, y1[/SUB) for some constant k. Then Y0=(1+ik)Y1. Then use the fact that Y0 is an eigenvector of A and that AY1 contains no imaginary part.
AY=λY
Honestly, not too sure where to start for this one. I know I should begin by considering the scenario where Y1 and Y2 are not linearly independent, but I do not know where I should begin with this information. Thanks for your help :)
AY=λY
You have ##A Y_0 = \lambda Y_0##, ##\lambda = \alpha +i \beta## and ##Y_0= Y_1+iY_2##.
Start by expressing ##A Y_0 = \lambda Y_0## in terms of the real numbers ##\alpha, \beta## and the real vectors ##Y_1, Y_2##.
okay so I would have A(Y1 + iY2)=(α+iβ)(Y1 + iY2)
and then I suppose I would multiply this out
Yes, do that. Remember that ##A, Y_1, Y_2, \alpha, \beta## are all real. This will give you two equations (by setting the real and imaginary parts of the resulting equation equal to each other).
Then assume that ##Y_1, Y_2## are linearly dependent, and see what that gives. At this stage, remember that ##\beta \neq 0##.
(Or you could reverse the order, first assume that ##Y_1, Y_2## are linearly dependent, and then do the multiplication.)
okay so the two equations I get (by setting the real and imaginary parts of the resulting equation equal to each other) is:
AiY2= iβY1 +αiY2 and AY1Y1Y2
but now what from here?
So you have ##AY_2=\beta Y_1 +\alpha Y_2##, ##AY_1=\alpha Y_1 - \beta Y_2## (*).
You want to prove that ##Y_1, Y_2## are linearly independent.
Assume that they are linearly dependent: that means that ##\exists k \in \mathbb R, k\neq 0## such that ##Y_1=k Y_2##.
Plug this in into the equations (*).
1. What is a complex eigenvalue?
A complex eigenvalue is a number that, when multiplied by a given matrix, results in a scalar multiple of the original matrix. It is a special type of eigenvalue that has both a real and imaginary component.
2. How is the proof for complex eigenvalues different from real eigenvalues?
The proof for complex eigenvalues involves using complex numbers and complex algebra, while the proof for real eigenvalues only involves real numbers and algebra.
3. What is the significance of complex eigenvalues in linear algebra?
Complex eigenvalues play a crucial role in understanding and solving systems of linear equations. They also have important applications in fields such as physics, engineering, and computer science.
4. Can complex eigenvalues have multiple solutions?
Yes, complex eigenvalues can have multiple solutions, just like real eigenvalues. This means that there can be multiple matrices that, when multiplied by the same complex eigenvalue, will result in the same scalar multiple.
5. How is the proof for complex eigenvalues related to the characteristic polynomial?
The proof for complex eigenvalues involves finding the roots of the characteristic polynomial of a matrix. These roots, also known as eigenvalues, are complex numbers and can be used to find the corresponding eigenvectors of the matrix.
