Concepts to understand Quantum Tunneling
In summary, understanding quantum tunneling at the undergraduate level requires knowledge of concepts such as energy, potential barriers, conservation of energy, differential equations, and the quantum mechanical wave function. While classically, a particle needs to have enough energy to cross the barrier, using quantum mechanics and the Schrodinger equation, it is possible for a particle to cross with lower energy without violating the principle of conservation of energy.
SameerTahir
What concepts should be cleared to better understand quantum tunneling?.
Likes Tio Barnabe
This is a very vague question.
At what level do you wish to understand this "quantum tunneling"? Understanding it at the intro QM course is different than understanding it at the graduate level/research level.
The prerequisite for an undergraduate QM class is a very good start to know what is needed to understand intro quantum tunneling.
Zz.
At undergraduate level.
Then I've given you an answer.
Zz.
Basically, they are the concepts of energy (kinetic and potential) , and the concept of potential barrier, and the principle of conservation of energy. Also must understand differential equations (the schrodinger equation is used at the introductory level) and also understand very well the concept of the quantum mechanical wave function that appears in schrodinger equation.
The potential barrier means that in order for something to cross the barrier and due to the conservation of energy, must have energy (kinetic+potential) greater or equal to the energy level of the potential barrier. But it turns out that this is only if you treat the problem classically.
However using quantum mechanics and the schrodinger equation one can show that a particle can cross (to be more accurate, and having in mind the probabilistic interpretation of the quantum mechanical wave function, that the probability to find a particle with lower energy than the energy level of the barrier, at the other side of the barrier, is not zero as we would expect classically but it is positive (however small but positive)) the barrier having energy lower than that of the potential barrier and without violating conservation of energy.
Likes SameerTahir
The thread level tag has been corrected accordingly.
1. What is quantum tunneling?
Quantum tunneling is a phenomenon in which a particle can pass through a potential barrier even though it does not have enough energy to surmount the barrier. This is possible because of the probabilistic nature of quantum mechanics, where particles can exist in multiple states simultaneously.
2. How does quantum tunneling occur?
Quantum tunneling occurs when a particle's wave function extends beyond the potential barrier, allowing it to have a small probability of being on the other side. This probability is dependent on the particle's energy, the height and width of the barrier, and the shape of the barrier.
3. What are some real-world applications of quantum tunneling?
Quantum tunneling has various applications in technology, such as in scanning tunneling microscopy and quantum tunneling transistors. It is also essential in understanding the behavior of radioactive particles and nuclear fusion reactions.
4. What are the challenges in studying quantum tunneling?
One of the main challenges in studying quantum tunneling is the difficulty in accurately predicting the probability of a particle tunneling through a barrier. This is because it involves complex mathematical equations and relies heavily on the particle's properties and the barrier's characteristics.
5. Can quantum tunneling be observed in everyday life?
Yes, quantum tunneling can be observed in everyday life, although it is usually on a very small scale. For example, it is responsible for the alpha decay of radioactive materials and the tunneling of electrons in electronic devices, such as flash memory. However, these effects are often not noticeable to the naked eye.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
