What Does a Negative Value for the Deceleration Parameter Imply in Cosmology?
In summary, the conversation discusses the general Taylor series for ##a(t)##, which can be rewritten in terms of the Hubble constant ##H(t_0)## and the deceleration parameter ##q(t_0)##. The equation for ##a(t)## shows that a negative value for ##q(t_0)##, as observed in the data, implies a positive value for the term ##\left[- \frac{1}{2} q(t_0) H^2(t_0) (t-t_0)^2\right]##.
redtree
285
TL;DR Summary
Understanding the definition
I note the general Taylor series for ##a(t)## as:
\begin{equation}
\begin{split}
a(t)&\approx a(t_0) + a'(t_0) (t-t_0) + \frac{1}{2!} a''(t_0) (t-t_0)^2 ...
\end{split}
\end{equation}
which I rewrite as:
\begin{equation}
\begin{split}
a(t)&\approx a(t_0)\left(1 + \frac{a'(t_0)}{a(t_0)} (t-t_0) + \frac{1}{2} \frac{a''(t_0)}{a(t_0)} (t-t_0)^2 + ... \right)
\end{split}
\end{equation}
In this context, the Hubble constant ##H(t_0)## is defined as follows:
\begin{equation}
\begin{split}
H(t_0) &\doteq \frac{a'(t_0)}{a(t_0)}
\end{split}
\end{equation}
and the deceleration parameter ##q(t_0)## is defined as follows:
\begin{equation}
\begin{split}
q(t_0)&\doteq -\frac{a''(t_0)}{a(t_0) H^2(t_0)}
\end{split}
\end{equation}
such that
\begin{equation}
\begin{split}
a(t)&\approx a(t_0)\left(1 + H(t_0) (t-t_0) - \frac{1}{2} q(t_0) H^2(t_0) (t-t_0)^2 + ... \right)
\end{split}
\end{equation}
My question: Does a negative value for ##q(t_0)##, which is what is observed in the data, therefore imply that the term ##\left[- \frac{1}{2} q(t_0) H^2(t_0) (t-t_0)^2\right]## is positive?
Space news on Phys.org
It seems that way yes
1. What is the deceleration parameter sign?
The deceleration parameter sign is a measure of the rate at which the expansion of the universe is slowing down or speeding up. It is denoted by the letter q and can be positive, negative, or zero.
2. How is the deceleration parameter sign calculated?
The deceleration parameter sign is calculated using the Hubble parameter (H) and its derivative with respect to time (H'). The formula for q is q = -H'/H^2.
3. What does a positive deceleration parameter sign indicate?
A positive deceleration parameter sign (q>0) indicates that the expansion of the universe is slowing down. This means that the gravitational pull of matter in the universe is strong enough to counteract the expansion caused by dark energy.
4. What does a negative deceleration parameter sign indicate?
A negative deceleration parameter sign (q<0) indicates that the expansion of the universe is speeding up. This means that the repulsive force of dark energy is stronger than the gravitational pull of matter.
5. What does a deceleration parameter sign of zero mean?
A deceleration parameter sign of zero (q=0) indicates that the expansion of the universe is neither slowing down nor speeding up. This could mean that the gravitational pull of matter and the repulsive force of dark energy are in balance, or that there is no dark energy present in the universe.
  • Differential Equations
