Denseness of irrationals in R
  • Thread starter fishturtle1
In summary, the proof first shows that the set of real numbers that are not rational is contained within the set of irrational numbers. Then, it uses the fact that irrationals are dense in the real numbers to show that for any two real numbers a and b where a is less than b, there exists an irrational number x between them. However, the proof fails when trying to show that the mean of a and b is irrational because of a mistake in defining one of the variables.
fishturtle1
394
82
Let ##\mathbb{I}## be the set of real numbers that are not rational; elements of ##\mathbb{Z}## are called irrational numbers. Prove if ##a < b##, then there exists ##x \epsilon \mathbb{I}## such that ##a < x < b##. (Hint: First show ##\lbrace r + \sqrt{2} : r \epsilon \mathbb{Q}\rbrace \subset \mathbb{I}##)
Well I can show the hint is true...
Proof: Let ##r = \frac mn \epsilon \mathbb{Q}##. Suppose, by way of contradiction, that ##r + \sqrt{2} = \frac pq \epsilon \mathbb{Q}##. Then ##\sqrt{2} = \frac pq - \frac mn = \frac{pn - mq}{qn} = \frac{p'}{q'}## where ##p' = pn - mq## and ##q' = qn##. Thus, ##\sqrt{2}## is rational, a contradiction. We can conclude ##r + \sqrt{2}## is irrational, thus ##\lbrace r + \sqrt{2} : r \epsilon \mathbb{Q} \rbrace \subset \mathbb{I}##. ##\square##
So I'm thinking given any a, b such that ##a < b##, we need to add/subtract something starting at ##\sqrt{2}## so that we end up somewhere between ##a## and ##b##..
Proof: We will show the irrationals are dense in ##\mathbb{R}##. Suppose ##a, b \epsilon \mathbb{R}## such that ##a < b##. Then there exists ##l_1, l_2 \epsilon \mathbb{R}## such that ##a = \sqrt{2}\cdot l_1## and ##b = \sqrt{2}\cdot l_2##. So ##a < \frac{a+b}{2} = \frac{\sqrt{2}(l_1+l_2)}{2} < b##. So ##a < \frac{l_1+l_2}{\sqrt{2}} < b##.
Now we show ##\frac{l_1+l_2}{\sqrt{2}}## is irrational. We proceed by contradiction. Suppose ##\frac{l_1+l_2}{\sqrt{2}}## is rational. Then ##\frac{l_1+l_2}{\sqrt{2}} = \frac pq## where ##p,q## are relatively prime integers. Then ##l_1+l_2 = \frac{p\sqrt{2}}{q}##. So ##\sqrt{2} = \frac{q(l_1+l_2)}{p}##. Let ##h = q(l_1+l_2) \epsilon \mathbb{Z}##. So ##\sqrt{2} = \frac hp##. Thus ##\sqrt{2}## is rational, a contradiction.
We can conclude there exists an irrational number ##x## such that ##a < x < b##.
##\square##But this can't be right because the number we showed to be irrational was the mean of ##a## and ##b## so that's saying ##3 < 5## implies 4 is irrational...
I didn't really think about fractions being in simplified form because isn't the set of rationals a bunch of equivalence classes? like 4/10 isn't in reduced form but its still rational... But I'm thinking maybe this is why my proof fails for some reason?
My question is where did my proof go wrong?
Easier:
Suppose ##r + \sqrt{2}## is rational. Then, since the rationals are closed under addition, it follows that ##\sqrt{2} = r + \sqrt{2} + (-r)## is rational. An obvious contradiction.
This line is wrong.
Did you learn about the sequential characterisation of closures? If you did, here's a proof that uses this, but it is not difficult to find more elementary proofs.
You have to prove that ##\operatorname{cl}(\mathbb{I}) := \overline{\mathbb{I}} = \mathbb{R}##.
So, let ##x \in \mathbb{R}##. We will show that we can write ##x## as a limit of irrationals, using your hint.
If ##x## was irrational, just take a constant sequence. If ##x## is rational, no worries. Define the sequence ##(x_n)_n## by ##x_n:= x + \frac{\sqrt{2}}{n}##. Then, ##(x_n)_n## is a sequence that lives in the irrationals with limit ##x##, and you are done.
You defined ##l_1## and ##l_2## as real numbers and ##q## as an integer and then said ##q(l_1+l_2) \epsilon \mathbb{Z}##. So now you have forced ##l_1+l_2## to be EDIT: rational, which means ##a+b = \sqrt 2(l_1+l_2)## has to be irrational.
I suggest that you consider two cases: 1) ##a## is rational, and 2) ##a## is irrational. Then choose an irrational number or rational number, respectively, less than ##b-a## and add it to ##a##.
Thanks for both replies!
Math_QED said:
Easier:
Suppose r+√2r+2r + \sqrt{2} is rational. Then, since the rationals are closed under addition, it follows that √2=r+√2+(−r)2=r+2+(−r)\sqrt{2} = r + \sqrt{2} + (-r) is rational. An obvious contradiction.
thats awesome
just for the sake of it... Let ##a## be irrational and ##r## be rational. Suppose, by way of contradiction, that ##a+r## is rational. Since rationals are closed under addition, we can see ##(a+r)+-r = a+(r+-r) = a +0 = a##. So ##a## is rational, a contradiction. We can conclude the sum of a rational and irrational is irrational.
I don't think I learned about sequential characteristics of closure yet but metric space is in a few chapters so yea.. I'd like to come back to this.
Using post #4's suggestion
Proof: We will show ##\mathbb{I}## is dense in ##\mathbb{R}##. Let ##a < b## and consider 2 cases:
case 1: ##a \epsilon \mathbb{I}##. We know there are infinitely many rationals in ##(a,b)##. Let ##q_1, q_2## be rationals in ##(a,b)## such that ##q_1 < q_2##. Then ##\frac{q_2 - q_1}{2} < b - a##. We know ##\frac{q_2 - q_1}{2}## is rational, so ##a + \frac{q_2 - q_1}{2}## is irrational and in ##(a,b)##.
case 2: ##a \epsilon \mathbb{Q}##. It seems ##(\sqrt{2} + (b-a)\cdot l) \epsilon (a,b)## for some ##l \epsilon \mathbb{Z}##. Still working on proving this...
thats awesome
Let's simplify case 1. What is a rational number ##q < b-a##? Try ##q = \frac 1 n## where ##n \in \mathbb{Z^+}##. How can you find a value of ##n## that satisfies the inequality?
So ##\frac 1n < b - a## is equivalent to ##n > \frac{1}{b-a}##. To find an integer ##n## satisfying this we can take ##n = \lceil \frac{1}{b-a} \rceil##.
So for case 1: Let ##a## be irrational. Observe that ##\frac 1n < b - a## is equivalent to ##n > \frac{1}{b-a}##. An integer solution for this is ##n := \lceil \frac{1}{b-a} \rceil##. Since a is irrational and ##\frac 1n## is rational, we can conclude ##a + \frac 1n## is irrational. Also ##a < a + \frac 1n < b##.
case 2: Let ##a## be rational. From our case 1, we can see ##n := \lceil \frac{1}{b-a} \rceil + \sqrt{2}## also satisfies ##\frac 1n < b - a##. Also, ##n## is the sum of a rational number and irrational number, thus ##\frac 1n## is irrational. By the same logic, ##a + \frac 1n## is irrational. Also ##a < a + \frac 1n < b##.
We can conclude for all ##a,b \epsilon \mathbb{R}## such that ##a < b##, there exists an irrational number ##x## such that ##a < x < b##.
##\square##.
Right, now can you modify that argument so prove case 2?
Likes fishturtle1
I edited case 2 into the previous post, thank you for your help
What is the definition of "denseness of irrationals in R"?
The denseness of irrationals in R refers to the property of the set of irrational numbers being densely packed within the set of real numbers. This means that between any two real numbers, there exists an infinite number of irrational numbers.
How is denseness of irrationals in R related to the concept of infinity?
The denseness of irrationals in R is closely related to the concept of infinity because it means that the set of irrational numbers is infinite and uncountable. This is because between any two irrational numbers, there are an infinite number of other irrational numbers, making it impossible to list them all.
Is every real number an irrational number?
No, not every real number is an irrational number. Real numbers include both rational and irrational numbers. Irrational numbers are a subset of real numbers and they cannot be expressed as a ratio of two integers, while rational numbers can.
What is an example of an irrational number?
An example of an irrational number is pi (π), which is approximately 3.14159. Other examples include the square root of 2 (√2), Euler's number (e), and the golden ratio (φ).
Why is it important to understand the denseness of irrationals in R?
Understanding the denseness of irrationals in R is important because it helps us to better understand the nature of real numbers and their relationship to each other. It also has practical applications in fields such as mathematics, physics, and engineering where precise measurements and calculations are necessary.
  • Electromagnetism
