How Has Our Understanding of the Atom Changed Since Thomson's Model?
  • Thread starter Air
  • Tags
    Nucleus
In summary, since JJ Thomson's discovery of the electron in 1897, our model of matter on a subatomic scale has undergone significant changes. The first major change was the development of the nuclear atom model, which replaced Thomson's "bun" model. This was supported by the results of the alpha scattering experiment, which showed large angles and disproved the idea of electrons embedded in a positively charged mass. The next change was the discovery of protons and neutrons in the nucleus, thanks to Chadwick's experiment in 1932. This led to the understanding that atoms are composed of a positively charged nucleus surrounded by negatively charged electrons. Further advancements in technology, such as deep inelastic scattering, revealed the existence of qu
Air
203
Question:
In 1997 we celebrated the centenary of JJ Thomson’s discovery of the electron. Thomson pictured the atom as being like a currant bun, with electron ‘currants’ embedded in a positively charged ‘bun’. Give a short account of three ways in which our model of matter on a subatomic scale has changed since Thomson’s discovery. For each, state clearly how the model changed, and write a few sentences outlining one piece of evidence that played a part in bringing about the change.
My response:
I've outline the point, but cannot expand on it, can I have help on the detail:
  • Nuclear atom - Alpha scattering: large angles. Incompatible with bun model.
  • Protons and neutrons in nucleus - Chadwick’s experiment: neutral particle of same mass as H.
  • Quarks (existence of) - Deep inelastic scattering: structure within proton.
  • Momentum of electromagnetic radiation - de Broglie theoretical prediction.
  • Antimatter Anderson’s observation of e - like particle with positive charge.
  • Neutrinos - “Missing” energy in beta decay.
1. It looks like you just pasted some tidbits about subatomic particles without actually looking to answer the given question,
2. You need to look up what different models of the atom involve,
3. There's a clear emphasis on electrons in the question - as there should be for a question on atomic structure - so don't ignore them.
Since JJ Thomson's discovery of the electron in 1897, our understanding of the subatomic world has undergone significant changes. The first major shift in our model of matter came with the discovery of the nucleus, which replaced Thomson's "currant bun" model. This change was brought about by the famous alpha scattering experiment conducted by Ernest Rutherford in 1911. This experiment involved firing alpha particles at a thin sheet of gold foil and observing their deflection. The results showed that most of the particles passed straight through, but a small percentage were deflected at large angles. This was incompatible with Thomson's model, as it suggested that the majority of the atom's mass was concentrated in a small, dense nucleus rather than being spread out evenly.
The next major change in our model of matter came with the discovery of protons and neutrons in the nucleus. This was made possible by James Chadwick's experiments in 1932, where he bombarded beryllium with alpha particles and observed the emission of a neutral particle with the same mass as a hydrogen atom. This discovery led to the development of the nuclear model of the atom, which placed protons and neutrons in the nucleus and electrons in orbit around it.
In the 1960s, the existence of even smaller particles within protons and neutrons was revealed through deep inelastic scattering experiments. This evidence, along with theoretical predictions by Louis de Broglie, led to the recognition of quarks as the fundamental building blocks of protons and neutrons.
Another significant change in our model of matter came with the discovery of antimatter. In 1932, Carl Anderson observed a positively charged particle with the same mass as an electron, which he named the positron. This discovery challenged the idea that all particles have a positive charge, as proposed by Thomson's model.
Finally, the existence of neutrinos was confirmed in the 1950s through the observation of "missing" energy in beta decay experiments. This evidence suggested that a neutral particle, later identified as the neutrino, was also involved in the process.
Overall, our understanding of the subatomic world has evolved significantly since Thomson's discovery of the electron. Through various experiments and theoretical predictions, we have come to understand the complex structure of matter on a subatomic scale and continue to make new discoveries and advancements in this field.
1. What is the nucleus?
The nucleus is the central part of an atom that contains protons and neutrons. It is often referred to as the "brain" of the atom because it controls its chemical and physical properties.
2. How was the nucleus discovered?
The nucleus was discovered by English physicist Ernest Rutherford in 1911 during his famous gold foil experiment. He bombarded a thin sheet of gold with alpha particles and observed that some particles were deflected at large angles, suggesting the presence of a small, dense, and positively charged center in the atom.
3. What is the function of the nucleus?
The main function of the nucleus is to store and protect the genetic material of an organism, which is made up of DNA molecules. It also controls the activities of the cell by regulating gene expression and synthesizing important molecules like RNA and ribosomes.
4. How does the nucleus contribute to atomic stability?
The nucleus contributes to atomic stability in two ways. First, the strong nuclear force, which is responsible for holding the nucleus together, is much stronger than the electromagnetic force between protons, preventing the positively charged protons from repelling each other. Second, the nucleus contains neutrons, which act as a "buffer" between the positively charged protons, adding stability to the atom.
5. Can the nucleus be split?
Yes, the nucleus can be split through a process called nuclear fission. This occurs when a large nucleus, such as uranium, is bombarded with neutrons, causing it to split into smaller nuclei and releasing a large amount of energy. Nuclear fission is the basis for nuclear power and nuclear weapons.
  • Sticky
  • Quantum Physics
