Kumo
- 22
- 1
Hi Everybody,
I am currently battling with the fourth and final question of my A Level physics work for this week. The problem has been driving me crazy, as I seemed to have completed all of the relevant steps, and I find the right answer only with negative exponents, which isn’t much help at all.
It then proceeds to ask questions for the electric force on the α-particles at the surface, and the electric potential of the nucleus, which I was fine with after a few tries. However, question (d) asks the following.
[itex]W=\frac{kqQ}{r}[/itex] or [itex]E= \frac{V}{d}[/itex] together with [itex]V=\frac {kQ}{r}[/itex]
I decided to tackle the problem in two ways, the first is as follows using the electric potential energy formula given above.
[itex]W = \frac{qkQ}{r}[/itex]
[itex]W = \frac{(8.99 * 10^9) * (3.2 *10^{-19}) * (1.44 * 10^{-17})}{(8 * 10^{15})}[/itex]
[itex]W = \frac{(4.143 * 10^{-26})}{(8 * 10^{15})}[/itex]
[itex]W=5.18 * 10^{-12}[/itex] J
This is pretty much the same answer that I found in the back of the book, only with a negative exponent.
My next attempt was a bit of a shot in the dark, but I tried it regardless.
[itex]V = \frac{kQ}{r}[/itex]
[itex]V = \frac{(8.99 * 10^9) * (3.2 * 10^{19})}{(8.0 * 10^{19})}[/itex]
[itex]V = \frac{(2.877 * 10^{-19}}{(8 * 10^{-19}}[/itex]
[itex]V = \frac{3.6 * 10^{-1}}V[/itex]
[itex]E = \frac{V}{d}[/itex]
[itex]E = \frac{(3.6 * 10^{-1})}{(7*10^{-19}}[/itex]
[itex]E = 4.5 * 10^{18} J[/itex] J
I would really appreciate it if someone could shed some light on this issue, as it has really been bugging me. Thank you very much for any help and your time.
In a simplified model, a uranium nucleus is a sphere of radius 8.0 * 10-15m. The nucleus contains 92 protons (and rather more neutrons). The charge on a proton is 1.6 * 10-19. It can be assumed that the charge of these protons acts as if it were all concentrated at the centre of the nucleus. The nucleus releases an α-particle containing two protons (and two neutrons) at the surface of the nucleus.
Calculate: the electric potential energy of the α-particle when it is at the surface of the nucleus.
