Elimination of quantifiers
  • MHB
  • Thread starter mathmari
  • Tags
    Elimination
In summary, the conversation discusses the elimination of quantifiers and its application to expressions involving polynomials and exponentials. The elimination of quantifiers is the process of finding an equivalent quantifier-free formula in a given structure. In the examples discussed, the quantifiers can be eliminated in the structure of exponentials, but not in the structure of polynomials. The structures mentioned, $\text{Exp}(\mathbb{C})$ and the polynomial structure, have operations of addition and multiplication by numbers. The predicate $T(x)$ is defined as $x \notin \mathbb{C}$, meaning that the function $x$ is not a constant function. However, the interpretation of $x$ as a function is not possible
mathmari
MHB
5,049
Hey! :eek:
I am looking at the elimination of quantifiers.
Let $T(x)$ be the predicate that $x$ is non-constant.
Consider the expression $$\exists x \left (x'+x=1 \land T(x) \right ) \tag 1$$
Since the solution of the differential equation $x'+x=1$ is $x(t)=1-Ce^{-t}$, we can eliminate the quantifier at $(1)$ when we are looking at the exponentials, but not when we are looking at the polynomials.
Is this correct?
Consider the expression $$\exists x \left (x'+x=t \land T(x) \right ) \tag 2$$
Since the solution of the differential equation $x'+x=t$ is $x(t)=Ce^{-t}+t-1$, we cannot eliminate the quantifier at $(2)$ neither at the case of polynomials nor at the case of exponentials.
Is this correct?
Could you explain what you mean by "eliminating the quantifier" and "looking at the exponentials"?
Let $\mathcal{A}$ be a structure, for example $\text{Exp}(\mathbb{C})$.
Elimination of quantifiers:
For each formula $\psi$ there is a formula $\psi_0$ without quantifiers such that in the strucutre $\mathcal{A}$ the following is a tautology: $$\exists x \ \ \psi (x) \leftrightarrow \psi_0$$ i.e., $$\mathcal{A} \models \exists x \ \ \psi (x) \leftrightarrow \psi_0$$ For example, when we have the formula $$\exists x \left (x'+x=0 \land T(x)\right )$$ since the solution is $x(t)=Ce^{-t}$, in the structure $\text{Exp}(\mathbb{C})$, i.e., at the exponentials, we can eliminate the quantifier (the existential symbol $\exists$) since $$\exists x \left (x'+x=0 \land T(x)\right ) \leftrightarrow Ce^{-t}$$
But in the structure of polynomials we cannot eliminate the quantifier, since the solution is not a polynomial.
I'll say up front that I am not very knowledgeable at quantifier elimination, so I can provide only "common sense" discussion. It's OK if this is not sufficient for you.
What is $\text{Exp}(\mathbb{C})$ and what is the polynomial structure you are talking about?
What is $T(x)$? You can't say $\dots\leftrightarrow Ce^{-t}$ because the right-hand side is not a formula. Also, why not say $\exists x \left (x'+x=0 \land T(x)\right ) \leftrightarrow\top$ where $\top$ is some tautology?
Are you working with first-order logic? If yes, then how do you quantify over the function $x$?
We define $\text{Exp}(\mathbb{C})$ to be the set of expressions $$a=a_0+a_1 e^{\mu_1 z}+ \dots +a_Ne^{\mu_N z}$$ (beyond the "zero function", $0$, which we will consider to be also an element of $\text{Exp}(\mathbb{C})$)
where $a_0, a_1, \dots , a_N \in \mathbb{C} \setminus \{0\}$ and $\mu_i \in \mathbb{C} \setminus \{0\}$; in writing such an expression we will always assume that the $\mu_i$ are pairwise distinct.
The polynomials structure is the set of expressions $$p=p_0+p_1 z+ \dots +p_N z^N$$
What is $T(x)$?
$T$ is a one-place predicate, meaning: $$T(x) \Leftrightarrow x \notin \mathbb{C}$$ i.e. $T(x)$ means that the function $x$ is not a constant function.
So the right-hand side should be an expression containing $"="$ ?
Do you mean that it should be of the form $\exists x \left (x'+x=0 \land T(x)\right ) \leftrightarrow 0=0$ ?
Yes.
What do you mean?
First of all, elimination of quantifiers for closed formulas is trivial. If you have a closed formula $A$ (i.e., $A$ has no free variables) and a stricture $\mathcal{S}$, then either $\mathcal{S}\models A$ or $\mathcal{S}\not\models A$. In the first case, you can take some tautology $\top$ (yes, for example, $0=0$); then $\mathcal{S}\models A\leftrightarrow\top$. In the second case take a contradictory formula $\bot$ (e.g., $\bot=\neg\top$); then $\mathcal{S}\models A\leftrightarrow\bot$.
The whole point of quantifier elimination lies in formulas with free variables. For example, if $A(x,\vec{y})$ has free variables $x$ and $\vec{y}$, then one has to find a quantifier-free formula $B(\vec{y})$ such that $\mathcal{S}\models \forall\vec{y}\;\big((\exists x\,A(x,\vec{y}))\leftrightarrow B(\vec{y})\big)$.
And the operations in these structures are addition and multiplication by numbers?
Yes, sorry I did not see this in post #1. But wait, if $x \notin \mathbb{C}$ means that $x$ is not a constant function, then $\Bbb C$ is not the set of complex numbers?
Yes.
mathmari said:
What do you mean?
What exactly is the signature (i.e., constants as well as functional and predicate symbols) of your logic? In first-order logic variables can quantify over elements of the domain (or universe), but not over functions over the domain. If the structure is natural numbers, then variables range over numbers, not numerical functions. So in first-order logic one cannot write a predicate $T(x)$ saying $\exists t_1,t_2\;x(t_1)\ne x(t_2)$ because here $x$ acts as a functional symbols and is supposed to be interpreted as a function.
But I assume you are viewing elements of the domain as formal expressions and not as functions. I.e., the polynomial $p_0+p_1 z+ \dots +p_N z^N$ is viewed simply as the sequence $(p_0,\dots,p_n)$, and being non-constant means that the length of the sequence is greater than 1. Is this so?
In any case, quantifier elimination for closed formulas is trivial.
We looking at the language $L=\{+, ' , T, 0, 1\}$ and the operations are on these structures. ( $'$ is the symbol of differentiation.)
I found this definition here:
In my notes there is the following:
($=$ is meant to be included in $L$)
First-order Logic: $Q_1 x_1 \dots Q_m x_m \ \ [\phi ]$
where $Q_1, \dots , Q_m$ are the quantifiers ($\exists , \forall$),
$\phi$ is a boolean combination of atomic formulae ( $t_1 R t_2$ (where $t_1, t_2$ are terms, $R$ is a predicate), $R(t)$ (where $R$ is a predicate) )
The terms can be built from the elements of the language. Terms are for example: $0$, $x$, $x+y$, $x'$, $(x+y)'+x'+1+1$
A sentence without quantifiers has no variables, for example $1=0$, $1'=0$.
Reduction of sentences to sentences without quantifiers.
Let $\mathcal{A}$ be a structure in that we interpret $L$, for example $\text{Exp}(\mathbb{C})$.
For each formula $\psi$ there is a formula $\psi_0$ without quantifiers such that in the strucutre $\mathcal{A}$ the following is a tautology: $$\exists x \ \ \psi (x) \leftrightarrow \psi_0$$ i.e., $$\mathcal{A} \models \exists x \ \ \psi (x) \leftrightarrow \psi_0$$ It suffices to mention only the existential formulas since $$\neg \exists x \ \ \psi (x)\equiv \forall x \ \ \neg \psi (x) \\ \neg \forall x \ \ \psi (x)\equiv \exists x \ \ \neg \psi (x)$$
$$L=\{+, -, ', T, 0, 1\}$$
$$\models \exists x \ \ \left (x=a \land x=b\right ) \leftrightarrow a=b \\ \exists x \ \ \left (x+y=a \land x-y=b\right ) \leftrightarrow 2y=a-b$$
A term $t$ is of the form $$t\equiv t(x)+t_0$$ that means that $t(x)$ is a term that contains $x$, that is constructed by the language $L$, and $t_0$ is constructed by the language $L$ and it doesn't contain $x$.
We interpret the structure in the language $L=\{+, ' , T, 0, 1\}$. $x$ is a term of the language and $x'$ is definable.
So $x$ is not a function. That's why we can quantify over $x$.
Is this correct?
1. What is the elimination of quantifiers?
The elimination of quantifiers is a process in logic and mathematics where a statement containing a quantifier, such as "for all" or "there exists", is rewritten without the use of the quantifier. This allows for easier manipulation and evaluation of the statement.
2. Why is the elimination of quantifiers important?
The elimination of quantifiers is important in many areas of mathematics, computer science, and philosophy. It allows for clearer understanding and evaluation of statements, and also enables the use of tools such as proof by induction and model checking.
3. How is the elimination of quantifiers performed?
The specific method for elimination of quantifiers depends on the type of quantifier being used. For universal quantifiers (e.g. "for all"), the statement is rewritten as a conjunction of individual statements. For existential quantifiers (e.g. "there exists"), the statement is rewritten as a disjunction of individual statements.
4. What are some common mistakes made when performing elimination of quantifiers?
One common mistake is incorrectly distributing negation when eliminating a quantifier. Another mistake is forgetting to specify the domain of the quantified variable when rewriting the statement without the quantifier.
5. Are there any limitations to the elimination of quantifiers?
The elimination of quantifiers can only be applied to statements in first-order logic, and it is not always possible to eliminate quantifiers from a statement while preserving its meaning. In some cases, the resulting statement after elimination may become too complex to be practically useful.
