Energy per particle of polarized electron gas
In summary, the task is to calculate the total internal energy per electron at zero temperature for a free noninteracting gas of electrons with density n in two cases: (a) where states with both spin directions are equally populated, and (b) where the gas is fully polarized with only one spin direction populated. The difference between the two cases lies in the Fermi level and Fermi radius, resulting in a difference in the total internal energy per electron.
cscott
782
Calculate the total internal energy per electron at zero temperature of a free noninteracting gas of electrons of density [itex]n[/itex], in the following two cases.
a) First assume that states with both spin directions are populated equally.
b) Now assume that the gas is fully polarized: only states corresponding to one spin direction, say "up", are populated.
Know internal energy per particle is given by,
[tex]\frac{U}{N} = \frac{1}{N} \sum_{k\sigma} \epsilon_k n_F(\epsilon_k)[/tex]
where [itex]\sigma[/itex] is summing spin states giving me a factor of one or two.
Eventually I get to,
[tex]\frac{U}{N} = \frac{1}{n} \int_{0}^{\inf} g(\epsilon})\epsilon n_F(\epsilon) d\epsilon[/tex]
where [itex]\sigma[/itex] is wrapped into the density of states [itex]g(\epsilon)[/itex] and [itex]n_F(\epsilon)[/itex] is the Fermi-Dirac distribution.
So is it correct that the last difference between (a) and (b) (that isn't carried by [itex]\sigma[/itex]) is the chemical potential [itex]\mu = \epsilon_F[/itex] in [itex]n_F(\epsilon)[/itex], where the polarized spins will have a Fermi radius twice as large as the non-polarized equally populated spins?
Trying to understand setting up the calculation right now more than performing it...
Yes, your understanding is correct. In case (a), the Fermi level will be at the same energy for both spin directions, so the Fermi radius will be the same. But in case (b), the Fermi level will only correspond to one spin direction, so the Fermi radius will be twice as large. This will result in a difference in the total internal energy per electron between the two cases.
Related to Energy per particle of polarized electron gas
1. What is energy per particle of polarized electron gas?
The energy per particle of polarized electron gas refers to the amount of energy that each electron in the gas possesses. It is a measure of the kinetic energy and potential energy of the electrons in the gas.
2. How is energy per particle of polarized electron gas calculated?
The energy per particle of polarized electron gas can be calculated using the equation E = (3/5)kT, where E is the energy per particle, k is the Boltzmann constant, and T is the temperature of the gas. This equation is based on the classical ideal gas law.
3. What factors affect the energy per particle of polarized electron gas?
The energy per particle of polarized electron gas is affected by several factors, including temperature, pressure, and the number of particles in the gas. It is also dependent on the properties of the material in which the electrons are moving, such as its density and composition.
4. How does the energy per particle of polarized electron gas differ from that of a non-polarized electron gas?
The energy per particle of polarized electron gas is typically higher than that of a non-polarized electron gas, as the polarization of the electrons increases their kinetic energy. Additionally, polarized electron gas can exhibit unique properties, such as magnetization and spin polarization, that are not present in non-polarized electron gas.
5. What are the applications of studying energy per particle of polarized electron gas?
Studying the energy per particle of polarized electron gas is important for understanding the behavior of materials under different conditions. It has applications in various fields, including materials science, condensed matter physics, and electronics. It can also provide insights into the properties of complex systems, such as quantum dots and nanoparticles.
