Equation with two variables (integers)
In summary, the conversation discusses solving the equation (x and y are integers) (x^3+4)(xy^2-x^2y+3y^2-12)=x^6, with the equations and attempts at a solution provided. The approach of narrowing down the possibilities for x candidates by looking at the integer factors of 16/(x^3+4) is suggested.
staples
Solve the equation (x & y are integers):
[itex](x^3+4)(xy^2-x^2y+3y^2-12)=x^6[/itex]
[tex]xy^2-x^2y+3y^2-12=\frac{x^6}{x^3+4} \\
xy^2-x^2y+3y^2-12=x^3-4 + \frac{16}{x^3+4} \\
16 \geq x^3+4 \\
x^3 \leq 12
[/tex]
That's all I can think of to do. I've tried expanding it and it doesn't seem to help. Any hints, please? Thanks.
Hi staples! http://img96.imageshack.us/img96/5725/red5e5etimes5e5e45e5e25.gif
Continuing on with your approach, we see that with all other terms being integers, then 16/(x3 +4) must also be a whole number, +ve or -ve, so that narrows it down to just a few possibilities for you to try for x candidates. :smile: Then try these one at a time to see whether you can find any corresponding y solution/s.
ooh, nice welcome-smilie, NascentOxygen! :smile:
(is that a self-portrait? o:))
Indeed. It's the spitting image.
Related to Equation with two variables (integers)
1. What is an equation with two variables (integers)?
An equation with two variables is a mathematical expression that contains two unknown numbers represented by letters, usually x and y. These variables can have multiple values that satisfy the given equation.
2. How do you solve an equation with two variables?
To solve an equation with two variables, you must find values for both variables that make the equation true. This can be done by using algebraic methods such as substitution or elimination, or by graphing the equation and finding the point where the line intersects with the x and y axes.
3. Can an equation with two variables have more than one solution?
Yes, an equation with two variables can have infinite solutions. This is because there are infinite combinations of numbers that can satisfy the equation.
4. What is the importance of equations with two variables in real life?
Equations with two variables are important in many real-life situations, such as calculating distance and time, determining the relationship between two quantities, and solving problems involving rates and ratios. They are also used in fields such as physics, economics, and engineering to model and solve complex problems.
5. How do you graph an equation with two variables?
To graph an equation with two variables, you must first rearrange the equation into the slope-intercept form y = mx + b, where m is the slope and b is the y-intercept. Then, plot the y-intercept on the y-axis and use the slope to find additional points on the line. Finally, connect the points to form a straight line on the graph.
