Finding the speed of a bicycle
The time t=4s is for 10m displaced not for 5m. So, to find the instantaneous speed at the 5m mark, we need to use the equation V=Vo+at, where Vo is the initial speed (0m/s) and a is the acceleration (1.25 m/s^2). Plugging in the values, we get:V=0+1.25(4)V=5m/sTherefore, the instantaneous speed at the 5m mark is 5m/s.
drwillis
Two physics students are trying to detemine the
instantaneous speed of a bicycle 5.0 m from the
start of a 1000 m sprint. It takes 4s to travel 10m. What is the instananeous speed at the 5m mark? acceleration is constant.
(5m mark is 10 m as they start at -5m)
X=Distance
U=initial speed (U= 0m/s)
Note. This is the first thing I've tried since joining year 11 so i am quite a novice and may have just made a stupid error
X=ut+1/2at^2
V=U+at
x=ut+1/2at^2
10=(1/2).(a).(16)
10=8.a
a=1.25
V=u+at
V=(1.25)(4)
V=5m/s
But the answers say it 3.5m/s.
Your acceleration is correct and you used the equation correctly except for the second part. The time t=4s is for 10m displaced not for 5m. So, let's look at the given:
a = 1.25 m/s^2
Vo = 0
Vf = ?
displacement = 5m.
Note: You have three given, so you should be able to solve for Vf (instantaneous speed).
you are right
Related to Finding the speed of a bicycle
1. How can I measure the speed of a bicycle?
The speed of a bicycle can be measured by using a speedometer, which is a device that calculates the speed based on the rotation of the bicycle's wheels.
2. Is there a formula for calculating the speed of a bicycle?
Yes, the formula for calculating the speed of a bicycle is: speed = distance/time. This means that if you know the distance traveled and the time it took, you can calculate the speed of the bicycle.
3. Can the speed of a bicycle be affected by external factors?
Yes, the speed of a bicycle can be affected by external factors such as wind resistance, road surface, and the weight of the rider. These factors can either increase or decrease the speed of the bicycle.
4. How accurate are speedometers in measuring the speed of a bicycle?
Speedometers are usually accurate in measuring the speed of a bicycle. However, factors such as tire pressure, wheel size, and calibration can affect the accuracy of the speedometer.
5. Can I use a GPS device to measure the speed of a bicycle?
Yes, a GPS device can also be used to measure the speed of a bicycle. It uses satellite signals to calculate the speed and can be more accurate than a speedometer in some cases. However, it may not work well in areas with poor satellite reception.
