Finding the temperature change of Earth's surface over 12 hours
In summary, the conversation discusses finding the velocity of air moving from the equator to the poles due to changes in pressure caused by differing temperatures. The speaker has found the flux density from the sun and factored in different albedos, but is now stuck and needs to find the total energy on 1m^2 of ground over 12 hours. They discuss using an integral and finding θ as a function of time. The conversation also touches on rearranging Bernoulli's theorem and using degrees vs. radians in calculations.
leonmate
84
Ok, this question goes on a little further. I want to find the velocity of air moving from the equator to the poles due to the change in pressure caused by differing temperatures.
I've found the flux density from the sun, so I have a value of flux (hope I am using the right term here - whatever W/m^2 is) for the equator and the N pole and I factored in different albedos too :approve:
But now I'm stuck.
I have a flux on the equator, so energy/s for 1m^2 essentially. I want to find how much the surface heats up and use that to find how much that heats the column of air above it.
If we consider at sunrise the angle between the surface and the sunlight is 0°, at midday 90°, and sunset 180°. So we are going from minimum>maximum>minimum. I've drawn myself a graph, the maximum flux is 1270 W/m^2
As the sun moves across the sky, the 1m^2 of ground we are considering has a differing amount of flux on it as F = (Fmax) sinθ so we wind up with a graph that looks like the sin curve. What I want to know is how can I work out the total energy on this 1m^2 of ground over 12 hours (43200 seconds if that's easier)? I guess it's an integral but so far nothing has worked for me :cry:
well, you've got the equation F = (Fmax) sinθ which is the power on this 1m^2, right. So yes, to get the total incident energy, it is going to be an integral over time. So now, you need to find out what is θ as a function of time? hint: it is fairly simple, think about the rotation of the earth.
edit: also, I'm guessing you are making the assumption that it is the longest day on the equator, so that the equator is the point closest to the sun. (or equivalently, just ignoring the effect of the seasons).
Check out Introduction to Dynamic Meteorology by Holton
Ok, so I subbed 180*t/43200 as a value for θ into the integral:
E = ∫ Fmax*sin(t/240) dt and used the limits 0 - 43200
I found an answer to be 609600J.. seems like a good answer! Thanks :biggrin:
Just trying to figure out the change in air temperature because of that... need some help with this bit!
I jumped a step and rearranged bernoulli's theorem to find the change in velocity due to the change in pressure
hmm. your method looks good. But I get a different answer than you did. You are using Fmax=1270, right? Maybe you accidentally used pi=180 instead of the radians answer?
yeah, i used 1270.
I worked the whole thing through with degrees, shouldn't make a difference?
E = 240*Fmax*(-cos(t/240)
once you stick in limits of 0 and 43200 i get:
E = [240*Fmax*(-cos(180))] - [240*Fmax*(-cos(0))]
E = [240*Fmax*1] - [240*Fmax*-1] = 480*Fmax = 609600J
How did yours differ?
It is not OK to use degrees when the angle comes out of the sin function (when you did the integration). If the angle was only inside the sin function, then you can use degrees or radians, it doesn't matter. But when you're using an angle outside of a sinusoid function, you have to use radians.
For example, with radians the arc length = radius * angle But this equation only works when the angle is in degrees. And other similar formulas require radians, not degrees.
1. How do scientists measure the temperature change of Earth's surface over 12 hours?
Scientists use a variety of instruments such as thermometers, satellites, and weather stations to measure the temperature change of Earth's surface over 12 hours. These instruments collect data on air temperature, soil temperature, and water temperature.
2. What factors can affect the temperature change of Earth's surface over 12 hours?
The temperature change of Earth's surface over 12 hours can be affected by various factors such as sunlight, clouds, wind, humidity, and land use. These factors can impact the amount of heat absorbed or reflected by the Earth's surface.
3. Why is it important to monitor the temperature change of Earth's surface over 12 hours?
Monitoring the temperature change of Earth's surface over 12 hours is crucial for understanding our planet's climate and weather patterns. It helps scientists track changes over time and make predictions about future climate trends.
4. What techniques are used to analyze the data collected from measuring the temperature change of Earth's surface over 12 hours?
Scientists use various statistical and computational techniques to analyze the data collected from measuring the temperature change of Earth's surface over 12 hours. This includes data visualization, data modeling, and statistical analysis to identify patterns and trends.
5. How does the temperature change of Earth's surface over 12 hours contribute to global warming?
The temperature change of Earth's surface over 12 hours is one of the many factors that contribute to global warming. As the Earth's surface heats up, it can lead to changes in weather patterns, melting of ice caps and glaciers, and rising sea levels, all of which are consequences of global warming.
