How Fast Was the Police Car Going When It Was 27 Meters Behind Again?
  • Thread starter mohabitar
  • Tags
    Velocity
In summary, a car with a constant speed of 24 m/s is being chased by a police car that starts from rest and accelerates at a constant rate of 5.4 m/s^2. At t=8.89 s, the cop car catches the speeding car when it is going 48 m/s. The problem is to find the speed of the police car when it is 27 m behind the speeding car for the second time. The wording of the problem may be confusing, but it means when the cop car is 27 m behind the speeding car for the second time during the pursuit. By using basic kinematic equations, the speed of the police car can be found when it is 27 m behind the speeding
mohabitar
140
A car is speed at a constant 24 m/sec in a school zone. A police car starts from rest just as the speeder passes it and accelerates at a constant rate of 5.4 m/sec2.
Also, the cop catches the car at t=8.89 s and v=48.
How fast is the police car going when it is 27 m behind the speeding car for the second time?
So, I'm not sure if the wording here is what's confusing me, but I can't get the right answer. First of all, how can the cop car ever be behind the speeding car "for the second time"? If the car is at a constant velocity and the police car keeps accelerating, then once they meet for the first time, the cop car will always be ahead, so what does it mean for it to be behind the speeding car for the second time?
I attempted the problem using basic kinematic equations to try to first find when it is 27 m behind the car: v=48+5.4t and 27=0+48t+.5(5.4)t^2. And so I solved for t and plugged it into the first equation but that didn't get me the right answer. Maybe I'm just not understanding the problem..
The "second time" part seems weird to me.Did you try to find the speed of the police car when is 27m behind the first car. Is that the good answer? Also if you do it your way and calculate the the speed of the police car when is 27m in front of the car. You must account for the velocity of the first car in 27=0+48t+.5(5.4)t^2..V= 48m/s is the speed of the police car with respect to the starting point but you need V relative to the first car.You can then convert again to the rest frame speed.
AT time t = 0, the cop car was level the speeding car. A very short time later the cop car will have been 1m behind the speeding car [with the speeding car opening the gap quite rapidly].
When the cop car caught the speeding motorist, they were again level with each other, naturally.
Just before he caught the speeding car, the cop car will have been 1 m behind .
That is the second time he was 1m behind the speeding car!
Presumably during this pursuit, the maximum gap from cop car to speeding motorist was more than 27m.
That means the gap first open to 27m [the first time the cop car was 27m behind the speedster]. The gap then continued to open to the maximum gap, the cop car then began to close the gap, and at some point the gap was reduced to 27m [the second time the cop car was 27m behind the speedster]. The cop car continued to close the gap and eventually caught the speedster.
That's how it works.
1. What is velocity?
Velocity is a vector quantity that measures the rate of change of an object's position with respect to time. It includes both the speed and direction of the object's motion.
2. How is velocity different from speed?
While both velocity and speed measure the rate of change of an object's position, velocity also takes into account the direction of motion, whereas speed only measures the magnitude of the object's motion.
3. What is the formula for calculating velocity?
The formula for velocity is v = Δx/Δt, where v is velocity, Δx is the change in position, and Δt is the change in time.
4. How do I find the velocity of an object in a simple problem?
To find the velocity of an object in a simple problem, you will need to know the change in position and the change in time. You can then use the formula v = Δx/Δt to calculate the velocity.
5. What are the units of velocity?
The units of velocity are typically measured in meters per second (m/s) or kilometers per hour (km/h), depending on the system of measurement being used.
