What Distance from Earth Achieves Weightlessness for Astronauts?
In summary, weightlessness for astronauts in a spacecraft is achieved when the distance between the spacecraft and Earth is infinite, as this eliminates any normal force acting on them. However, there will always be a gravitational force present regardless of the distance between the two bodies.
bcjochim07
374
How far away from Earth does a spacecraft have to be for the astonauts in it to be weightless?
Is this correct:
Since the gravitational force is a long range force, no matter what finite distance the spacecraft and Earth are from each other, there will still be gravitational attraction. In order for the astronauts to be truly weightless the distance between the ship and the Earth would have to be infinite.
-I had second thoughts about what weightless meant. My book define weight as a normal force, so if the astronauts are floating around in the spacecraft , they have no normal force acting on them, but are they truly weightless?
You are correct. There is still a gravitational force whatever the distance. But if the vehicle you are traveling in is accelerating at the same rate you are due to that force, then that force produces no normal force. You have to choose one definition or the other. They don't agree. Most people would call astronauts 'weightless', even though in low Earth orbit the g force on them is not that much less than the ground.
Your answer is mostly correct, but there are a few things to clarify.
Firstly, weightlessness refers to the sensation of not feeling any gravitational force on your body. It does not necessarily mean that there is no gravitational force acting on you. So, in this case, weightlessness would occur when the astronauts are far enough away from Earth that they do not feel any gravitational force on their bodies.
Secondly, it is not necessary for the distance between the spacecraft and Earth to be infinite for the astronauts to be weightless. In fact, there is a specific distance at which the gravitational force between the two objects becomes negligible and the astronauts would feel weightless. This distance is known as the point of zero gravity or the Lagrange point, and it is approximately 1.5 million kilometers away from Earth.
Lastly, it is important to note that even at this distance, there is still a gravitational force acting on the astronauts and the spacecraft. However, the force is so small that it is practically negligible and can be considered as weightless.
In summary, weightlessness occurs when the astronauts are far enough away from Earth that they do not feel any gravitational force on their bodies, typically at a distance of 1.5 million kilometers. However, there is still a gravitational force acting on them, but it is so small that it can be considered negligible.
1. What is gravity?
Gravity is a force of attraction that exists between any two objects with mass. It is responsible for keeping us grounded on Earth and for holding the planets in orbit around the sun.
2. How does gravity affect weight?
Gravity affects weight by pulling objects towards the center of the Earth. The strength of the gravitational force depends on the mass of the objects and the distance between them. The greater the mass, the greater the gravitational force, and the more weight an object has.
3. What is the difference between weight and mass?
Weight and mass are often used interchangeably, but they are actually different concepts. Mass is a measure of the amount of matter in an object, while weight is a measure of the force of gravity acting on an object. Mass remains the same regardless of location, while weight can change depending on the strength of gravity.
4. How does gravity work in space?
In space, objects still have mass and are still affected by gravity, but the effects may seem different due to the absence of air resistance. Without air resistance, objects in free fall will continue to accelerate towards each other until they collide or are pulled apart by another force.
5. Can gravity be manipulated?
Currently, there is no known way to manipulate gravity. Scientists are still studying this force and trying to better understand its properties. However, we can manipulate objects and their weight by changing their mass or by using other forces to counteract the effects of gravity.
  • Classical Physics
