How fast must the women run?
In summary: I'm clueless.Try it...if it doesn't work, I'm clueless.In summary, a woman is on a train leaving the station at 3.5 m/s, with a friend running alongside the car at 7.0 m/s in the same direction. To keep up with her friend, the woman would need to walk at a speed of 3.5 m/s. Once the train reaches a speed of 10 m/s, the woman would need to walk at a speed of 3.0 m/s to keep up with her friend.
emily081715
208
A woman is on a train leaving the station at3.5 m/s , while a friend waving goodbye runs alongside the car she's in. Call the train's direction of motion the +x direction.
Once the train has reached a speed of 10 m/s, how fast must the woman walk, and in which direction, to keep up with her friend?
vxw=vxt+vtw
v= 10-3.5
This seems to me like a VERY poorly worded question. I see various interpretations, but yes, your answer is correct using one of them, although even with that, I don't think the "keep up with her friend" is anything like standard English using since it is the friend who is "keeping up". It would have been more correct to say "stay even with her friend"
Also, you did not specify the direction of the passenger's motion relative to the train. You have v, which normally stands for "velocity", a vector, shown as a scalar.
its not the correct answer though. mastering physics says it wrong
Well, then perhaps we are both misinterpreting the problem. As I said, I think it is poorly worded. Not clear, to me at least, exactly what they are asking for.
i still need help finding the answer
Well, good luck with that.
do you have any suggestions ?
Did you try -6.5?
Negative since she moves to the back of the train, while the train is moving in the positive x direction.
To be honest, it doesn't really make sense, since the problem says she's "walking", while 6.5 m/s is "sprinting".
Then again, seeing how poorly worded the problem is, perhaps it's still the correct answer.
Likes billy_joule
I like Serena said:
Did you try -6.5?
Yea I tried negative and still wrong
It is assumed that both activities occur at the same time interval...they move in same direction since one must approach the other from assumed reference start or origin.however,the question lacks good construct...The v=8.25m/s... one way is to linearise it with equations of motion...using v^2= u^2 + 2ax, for the train ,v= 10, u= 6.5, both in m/s...so,we obtain ,ax=28.875m/s ..(1),also considering the time interval for covering x,we use v=u+ at, so,at= 3.5m/s ...(2),therefore, using both equations,we can divide 1 by 2 ,velocity with which the woman must move to catch up with the friend or thingy is given by v= 28.875/3.5 m/s. = 8.25m/s...
Please, I want people to check this...
that anwser was incorrect too
Likes obanz2nd
vxw=vxt+vtw
v= 10-3.5
Is that the question as given to you, word for word ?
exact whole question:
Part A)If the friend is running at 7.0 m/s and moving in the same direction as the train, how fast must the woman walk, and in which direction, to keep up with him? answer: 3.5 m/s
Part B) Once the train has reached a speed of 10 m/s, how fast must the woman walk, and in which direction, to keep up with her friend?
Answer:?
Answer:?
Now let's see your attempt(s) .
10-3.5= 6.5 m/s
emily081715 said:
10-3.5= 6.5 m/s
In part B), What is it that moves at 3.5 m/s ?
should it be 10-7?
emily081715 said:
should it be 10-7?
since the bus is moving at 10 and the friend is running at 7
emily081715 said:
since the bus train is moving at 10 and the friend is running at 7
Try it .
SammyS said:
Try it .
it was 7-10= -3 m/s
emily081715 said:
it was 7-10= -3 m/s
What is the significance of the negative sign?
the friend on the train is moving in the opposite direction of the train, so she is basically running to the back of the train.making it negative
No, the answer in part a is NOT "3.5 m/s". As I have pointed out to you previously you keep expressing v as a scalar which is not correct.
both answers for the parts have already been marked correct so clearly i expressed them properly for this particular question
Yes.
So apparently the first answer being positive implied that the direction was toward the front of the train, and as you stated, negative implied motion toward the rear.
Then your instructor is being VERY sloppy. That doesn't make it right.
1. What is the average speed of a woman?
The average speed of a woman can vary greatly depending on age, physical fitness, and other factors. However, according to studies, the average running speed of women ranges from 6 to 8 miles per hour (mph).
2. How does a woman's running speed compare to a man's?
Generally, men have a higher average running speed compared to women due to biological and physiological differences. However, there are always exceptions and women can also achieve high running speeds through proper training and conditioning.
3. Is there a specific speed that women must run at?
No, there is no specific speed that women must run at. It depends on individual goals and abilities. However, for competitive races, there may be specific time requirements that women must meet in order to qualify or win.
4. Does a woman's running speed decrease with age?
As with any physical activity, a woman's running speed may decrease with age due to changes in muscle mass, flexibility, and stamina. However, with proper training and exercise, women can maintain and even improve their running speed as they age.
5. What factors affect a woman's running speed?
Several factors can affect a woman's running speed, including but not limited to: genetics, physical fitness and training, nutrition, age, and health conditions. Additionally, external factors such as weather, terrain, and elevation can also impact a woman's running speed.
