How Is Average Force Calculated in a Football Collision?
In summary, a football player with a mass of 85 kg throws a football with a mass of 0.8 kg at a post with a horizontal speed of 25 m/s. The ball bounces back with the same speed after being in contact with the post for 0.05 s. Using the equation FΔt=m(vf-vi), it is calculated that the average force exerted on the post by the ball is -800N. The mass of the football player is irrelevant in this scenario.
woaini
58
A football player whose mass is 85 kg throws a football with a mass of 0.8 kg against a post. The football hits the post traveling horizontally with a speed of 25 m/s, and then it bounces back with about the same speed. The football is in contact with the post for 0.05 s. What average force is exerted on the post by the ball?
m = 0.8 kg
vi = 25 m/s
vf = -25 m/s
t= 0.05s
FΔt=m(vf-vi)
F = [itex]\frac{m(vf-vi)}{Δt}[/itex]
F = [itex]\frac{0.8(-25-25)}{.05-0}[/itex] = -800N by the post.
Is the mass of the football player irrelevant?
Why would the mass of the football player be relevant? All he does is imparts the initial kinetic energy to the ball. The same thing could be done with a 3,000kg piece of equipment. So yes, the football player's mass is irrelevant.
So my calculations are correct without the football player's mass?
Looks good to me.
I would say that the mass of the football player may not be completely irrelevant, but it does not directly affect the calculation of the average force exerted on the post by the ball. The mass of the football player is much larger than the mass of the football, therefore the contribution of their mass to the overall force is negligible. The key factors in determining the average force are the mass and velocity of the football, as well as the time it is in contact with the post. These variables are all included in the equation for impulse, which is equal to the change in momentum of the football. The mass of the player does not significantly impact the momentum of the football and therefore does not significantly impact the average force exerted on the post.
1. What is impulse average force?
Impulse average force is a measure of the average force applied to an object over a period of time. It is calculated by dividing the change in momentum of the object by the time interval in which the force is applied.
2. How is impulse average force different from regular force?
Regular force is a measure of the strength or intensity of a push or pull on an object, while impulse average force takes into account the duration of the force. This means that a smaller force applied over a longer period of time can have the same impulse average force as a larger force applied over a shorter period of time.
3. What is the formula for calculating impulse average force?
The formula for impulse average force is Favg = Δp/Δt, where Favg is the average force, Δp is the change in momentum, and Δt is the time interval.
4. What are some real-life examples of impulse average force?
Examples of impulse average force include a baseball being hit by a bat, a person jumping onto a trampoline, and a rocket taking off into space. In each of these situations, a force is applied over a period of time, resulting in a change in momentum and an impulse average force.
5. How is impulse average force used in science and engineering?
Impulse average force is an important concept in understanding the effects of forces on objects. It is used in physics to analyze collisions and in engineering to design and test structures and machines. It is also a key factor in understanding the biomechanics of human movement and sports performance.
