How to Correctly Integrate \( \sqrt{1-x^2} \)?
In summary: The conversation is about integrating the function (1 - x^2)^\frac{1}{2}. Initially, the speaker wants to integrate by substituting x = sin u and then using the identity \cos 2u = 2\cos^2 u - 1 to simplify the integral. However, they realize that this approach is incorrect and someone suggests using absolute values. The speaker then tries to integrate using the absolute value of cosine but gets stuck and asks for help. They mention a program called "Derive 6" but it also seems to have trouble with the absolute values.
Sink41
EDIT: my tex is a little broken trying to fix
So i want to intergrate
[tex]
\int (1 - x^2)^\frac{1}{2} dx
[/tex]
i start off by saying
[tex]\sin u = x[/tex]
so
[tex]
\frac {dx} {du} = \cos u
[/tex]
then
[tex]
\int (1 - x^2)^\frac{1}{2} \cos u du
[/tex]
which is
[tex]
\int \cos^2 u du
[/tex]
and
[tex]
\cos2u = 2cos^2 u - 1
[/tex]
so therefore
[tex]
\frac {1} {2} \cos2u + \frac {1} {2}= cos^2 u
[/tex]
so you intergrate
[tex]
\int \frac {1} {2} \cos 2u + \frac {1} {2} du
[/tex]
which is
[tex]
\frac {1} {4} \sin 2u + \frac {u} {2}
[/tex]
and
[tex]
\sin 2u = 2\sin u \cos u = 2\sin u(1 - sin^2 u)^\frac {1} {2}
[/tex]
putting x into u gets
[tex]
\frac {x} {2} (1 - x^2)^\frac {1} {2} + \frac {\sin^-1 x} {2}
[/tex]
which I am pretty sure is wrong. So can someone show me how to intergrate (1-(X^2))^0.5 ? i think that using x = sinu is wrong but u = sinx doesn't get me far either. Probably something simple I've overlooked.
Absolute Values...
thats correct
arildno said:
Absolute Values...
Is that a subtle hint to stick the natural log function in there? because if you say
[tex]
u = 1 - x^2
[/tex]
then
[tex]
\int \frac{u^\frac{1}{2}}{(4 - 4u)^\frac{1}{2}} du
[/tex]
which looks sort of f'(x)/f(x) ish... ok tbh i have no clue why you said absolute value except it means always positive and is often in log when intergrating for some reason?
[tex]\sqrt{x^{2}}=?[/tex]
EDIT: tex is a work in progress... again :\
I'm guessing due to the fact -x and x give the same answer
[tex]\sqrt{x^{2}}=|x|[/tex]
So
[tex](1-(X^2))^\frac {1}{2} = (1-(|x| ^2))^\frac {1}{2} [/tex]
and answer is
[tex]
\frac {x} {2} (1 - |x| ^2)^\frac {1} {2} + \frac {\cosec x} {2}
[/tex]
I'm worried about the fact trig has appeared in the intergral because f(x) didnt have any? And differential of cosec x is -cosecx cotx ?
No..according to your (correct guess we must have:
[tex](\cos^{2}(u))^{\frac{1}{2}}=|\cos(u)|[/tex]
agreed?
agreed?
OK... so when i change cosu to sinu... since i have
[tex](\cos^{2}(u))^{\frac{1}{2}}=(1 - \sin^{2}(u))^{\frac{1}{2}}[/tex]
then i get
[tex](|1 - sin{2}(u)|)^\frac{1}{2}[/tex] out of it?
so the answer is
[tex]
\frac {x} {2} (|1 - x^{2}|)^\frac {1} {2} + \frac {\sin^{-1}(x)} {2}
[/tex]
I don't get what you're asking about; I have shown you that your flaw lies in your expression 5 in your original post.
instead of [tex]
\int \cos^2 u du
[/tex]
i should have
[tex]
\int \cos(u) | \cos(u) | du
[/tex]
That is correct!
Ok so how do i intergrate
[tex]
[/tex]
btw i found a trial of a program called "Derive 6" on a demo disk i got from a maths course. It intergrated
[tex]
[/tex]
like this (click on thumbnail for bigger picture):
http://img218.imageshack.us/img218/6961/intergration1hl2.th.png
Using that method can you avoid absolute values? I tried putting
[tex]
[/tex]
into it and it didnt like it much. Got stuck if you tried to get it to do it step by step. This is what it got if you went straight to the answer.
http://img213.imageshack.us/img213/4346/intergration2xv0.th.png
I don't think it likes or uses absolute values much. When i told it to intergrate tanx it didnt use absolute values in the answer unlike my textbook. So I'm hoping intergrating |cosx| isn't hard or complicated and the programs messing up?
Well, the maximal domain of your x-integrand is -1 to 1.
Divide your u-interval into those regions where the cosine is negative, and those where it is positive.
You lose no generality by assumin [itex]0\leq{u}\leq{\pi}[/itex]
Related to How to Correctly Integrate \( \sqrt{1-x^2} \)?
1. What is the formula for "Integrating (1-(X^2))^0.5?"
The formula for integrating (1-(X^2))^0.5 is ∫(1-x^2)^0.5 dx.
2. How do you solve the integral of (1-(X^2))^0.5?
To solve the integral of (1-(X^2))^0.5, you can use the substitution method where u = 1-x^2 and du = -2x dx.
3. What is the antiderivative of (1-(X^2))^0.5?
The antiderivative of (1-(X^2))^0.5 is (1/2)(x√(1-x^2) + sin^-1(x)) + C.
4. What is the domain of (1-(X^2))^0.5?
The domain of (1-(X^2))^0.5 is all real numbers between -1 and 1, inclusive.
5. How can I use the integral of (1-(X^2))^0.5 in real life?
The integral of (1-(X^2))^0.5 can be used in real life to calculate the area under a curve or to find the length of an arc.
