Intersection multiplicity
In summary, the multiplicity of a curve at a point is the highest power of the local parameter that divides the defining equation of the curve at that point. The intersection multiplicity of two curves at a point is the multiplicity of the product of their defining equations. The intersection multiplicities of all points of intersection of two curves can be determined by looking at the ideal generated by their defining equations. The notation $\mathcal{O}_{\mathbb{A}_k^2,O}$ refers to the local ring of the affine plane at the origin. The isomorphism between this local ring and $\mathbb C<1,y>$ can be obtained by eliminating the variable $x$ from the local ring.
Fermat1
187
Define the multiplicity of $f$ at $p$ and the interesction multiplicity of $f,g$ at $p$.
Let curves $A$ and $B$ be defined by $x^2-3x+y^2=0$ and $x^2-6x+10y^2=0$. Find the intersection multiplicities of all points of intersection of $A$ and $B$.
If we let $f=x^2-3x+y^2$ and $g=x^2-6x+10y^2$ my book simplifies $<f,g>$ to $<x,y^2>$. Then my book says that $\mathcal{O}_{\mathbb{A}_k^2,O}/<x,y^2>$ is isomorphic to $\mathbb C<1,y>$. What is meant by the notation $\mathcal{O}_{\mathbb{A}_k^2,O}$ and how do they get this isomorphism? Thanks
The multiplicity of a curve $A$ at a point $p$ is the highest power of the local parameter at $p$ that divides the defining equation of $A$. In other words, it is the number of times the curve "touches" the point $p$.
The intersection multiplicity of two curves $A$ and $B$ at a point $p$ is the multiplicity of the product of their defining equations at $p$. In other words, it is the number of times the two curves intersect at the point $p$.
In this case, the intersection multiplicities at any point of intersection of $A$ and $B$ can be determined by looking at the ideal generated by their defining equations, which in this case is $<x,y^2>$. The notation $\mathcal{O}_{\mathbb{A}_k^2,O}$ refers to the local ring of the affine plane $\mathbb{A}_k^2$ at the origin $O$. This is the ring of all regular functions on $\mathbb{A}_k^2$ that are defined at the origin.
The isomorphism between $\mathcal{O}_{\mathbb{A}_k^2,O}/<x,y^2>$ and $\mathbb C<1,y>$ can be obtained by using the fact that the quotient of a polynomial ring by an ideal is isomorphic to the ring of all polynomials in the variables not contained in the ideal. In this case, we are essentially "eliminating" the variable $x$ from the local ring, leaving us with a polynomial ring in the variable $y$ over the field $\mathbb C$.
What is intersection multiplicity?
Intersection multiplicity is a concept in algebraic geometry that measures the number of times two algebraic curves intersect at a point.
How is intersection multiplicity calculated?
Intersection multiplicity is calculated using the theory of ideals and the concept of tangent spaces. It involves finding the degree of the intersection of two curves at a point, which is then used to determine the intersection multiplicity.
Why is intersection multiplicity important?
Intersection multiplicity is important because it helps determine the behavior of algebraic curves at points of intersection. It is also used in the study of singularities and in the proof of important theorems in algebraic geometry.
Can intersection multiplicity be greater than 1?
Yes, intersection multiplicity can be greater than 1. This means that two curves intersect at a point with a higher degree than 1, indicating a more complex intersection.
What is the relationship between intersection multiplicity and tangency?
The intersection multiplicity at a point is equal to the number of tangents that the two curves have at that point. This means that if the intersection multiplicity is greater than 1, there are multiple tangents at the point of intersection.
  • Linear and Abstract Algebra
  • Math POTW for Graduate Students
