Is this right?, conservation of energy
In summary, the problem involves a water tank on a frictionless surface and the goal is to determine the final velocity of the tank once the water has run out. Different approaches are suggested, including using conservation of energy and momentum. The idea of the horizontal center of mass is discussed and it is determined that the center of mass cannot change.
  • #36
Rethinking it a bit, a simpler approach would be to let M be the total original mass of the tank plus water. You want to move a quantity m of that total mass (representing the water) through the pipe. Then
##(M - dm)dR = dm\;dr ~~~~## and as before, ##~~dr = L - dR##
##dR = L \frac{dm}{M}##
Integration is trivial, with limits 0 → m
##R = \frac{m}{M}L ##
  • #37
Ok so now the eqn for the distance traveled x = R=∫m/M *L with limits 0 &m
and final velocity =0.
Thanks!
  • #38
That's R=∫(L/M)*dm
Thanks!
  • #39
Thanks for the continuing help
Greatly appreciated.
  • #40
We'll see... :smile:
I've decided to add some confusion back into the mix. Upon rethinking the rethinking, I've decided that the previous form of the integration makes more sense :frown:
At some time partway through the emptying of the tank, let's say that an amount x of the water has already gone down the pipe. That leaves the tank plus remaining water with mass M-x. It's this remaining mass for which we need to find the dR associated with the next dx that's moved.
##((M - x) - dx) dR = dx\;dr##
##((M - x) - dx) dR - dx (L - dR) = 0~~~~~## because ##dr = L - dR##
##dR = L \frac{dx}{M - x} ##
Integrate that for x going from 0 to m, the mass of water drained. M is still the mass of the tank plus the initial amount of water.
EDIT: Changed variable dm to dx in order to have it reflect that it's affecting x, the water that's being shifted.
  • #41
ok so I have R = ∫L(dx/M-x) = ∫L (M-x)^-1 dx.
But then I have R= -L
Or could it be,,
R = -L(ln(M-x) + c
  • #42
Or could it be,,
R = -L(ln(M-x) + c
You need to plug in both limits (0 and m, the total mass of water drained).
  • #43
ok...
so x = R = (-L(ln(M-m)) - (-L(ln(M-0))
  • #44
sg001 said:
ok...
Pull out the L and combine the ln's.
  • #45
Finally...
x = R= -L(ln(M-m)-(M-0))
  • #46
sg001 said:
Finally...
You need to check your log manipulation math. ln(x) - ln(y) ≠ ln(x - y).
  • #47
Ohh yeah My bad simple yet stupid mistake.
x= R = -L(ln(M-m)-ln(M-0))
  • #48
Still review your log math operations; Those logs can be combined into a single log.
  • #49
woops
R = -L(ln((M-m)/(M-0)) = x
  • #50
sg001 said:
woops
It can still be cleaned up some. Drop the zero and use the fact that -ln(b/a) = +ln(a/b).
  • #51
Ok so I have now
R = L (ln(M/M-m)) = x
  • #52
sg001 said:
Ok so I have now
That looks much neater.
  • #53
Thanks again gneil!
  • #54
sorry gneill!
