Length contraction Griffiths
In summary, the length contraction \Delta x'=\gamma \Delta x is proven by Griffiths in his book (Intro to Electrodynamics, page 489) using a simple gedanken experiment with a train, lamp, and mirror. The question is raised as to why two directions of light are used instead of just one. It is explained that this is because the time dilation formula only applies to time measurements recorded on a single moving clock, and cannot be applied to the one-way travel time involving multiple clocks on the moving train. This explains why using different equations for the observer on the train and the observer on the ground gives incorrect results.
maxverywell
197
In Griffiths book (Intro to Electrodynamics, page 489) he uses one simple gedanken experiment with train, lamp and mirror, to prove the length contraction [tex]\Delta x'=\gamma \Delta x[/tex]. My question is why he uses two directions of light and not just only one?
For example, when we use, for observer in the train, [tex]\Delta t'=\frac{\Delta x'}{c}[/tex] instead of [tex]\Delta t'=2\frac{\Delta x'}{c}[/tex] and for observer in the ground [tex]\Delta t=\frac{\Delta x}{c-u}[/tex] instead of [tex]\Delta t=\frac{\Delta x}{c-u}+\frac{\Delta x}{c+u}[/tex], it gives us incorrect result. Why is this happening?
No one can explain this?
Let's suppose that the light is moving in direction in which the train is moving. So, for observer in the train:
[tex]\Delta t'=\frac{\Delta x'}{c}[/tex] (1)
and for observer in the ground:
[tex]\Delta t=\frac{\Delta x}{c-u}[/tex] (2)
Applying the time dilation formula [tex]\Delta t'=\frac{\Delta t}{\gamma}[/tex] to (1) and (2) we find that:
[tex]\Delta x=\frac{\gamma(c-u)\Delta x'}{c}[/tex]
Realize that the time dilation formula applies to time measurements recorded on a single moving clock. You can't apply it to the one-way travel time, since multiple clocks on the moving train are involved--those clocks are not in synch (according to the track frame). If you use the round trip time, which is measured on a single clock, then you can apply the time dilation formula.
Related to Length contraction Griffiths
1. What is length contraction according to Griffiths?
Length contraction refers to the concept in physics where an observer perceives an object to be shorter in the direction of its motion compared to its length when at rest. This phenomenon was first introduced by the physicist George Griffiths.
2. How does length contraction occur?
Length contraction occurs due to the effects of special relativity, where the relative motion between an observer and an object causes a difference in the perception of the object's length. This effect becomes more significant as the speed of the object approaches the speed of light.
3. Can length contraction be observed in everyday life?
No, length contraction can only be observed at speeds close to the speed of light. In everyday life, objects typically move at much lower speeds, so the effects of length contraction are negligible.
4. How is length contraction related to time dilation?
Length contraction and time dilation are two effects of special relativity that occur simultaneously. As an object's length contracts, its time also dilates, meaning that time appears to pass slower for the moving object compared to an observer at rest.
5. What is the significance of length contraction in modern physics?
Length contraction is a crucial concept in modern physics, as it helps explain the behavior of objects at high speeds and the consistency of the laws of physics across different frames of reference. It is also a fundamental principle in the development of theories such as special relativity and the standard model of particle physics.
11K
