What Is the Limit of {cos(m!*pi*x)}^{2n} as n and m Approach Infinity?
In summary: Yes, you're correct. If x is an integer, the limit is 1, and if x is not an integer, the limit is 0. And if m=x, the limit is always 1. Good job!In summary, the limit of {cos(m!*pi*x)}^{2n} as 'n' and 'm' go to infinity is 1 if x is an integer, 0 if x is not an integer, and 1 if m equals x. This can be proven by considering the bounded nature of cosine and the order in which the limits are taken.
anthony.g2013
What would be the limit of {cos(m!*pi*x}^{2n} as 'n' and 'm' go to infinity along with proof? Also x is real. I have no clue as to how to start the question. Please help! Thanks.
I tried to write the original function as e^[(ln(cos(m!*pi*x)/(1/2n)], but since not both the numerator and denominator go to zero, I couldn't use L'Hopital's Rule.
Other method I tried was using the power series expansion of cosine, but I am not sure how to deal with m!
Any hints or help will be greatly appreciated. Thanks!
Consider the fact that cosine is bounded between -1 and 1.
Actually I should clarify the question and mu doubt:
the actual question is Evaluate lim m→infinity [lim n→ infinity ((cos (m!*pi*x))^2n) ].
So if we went with -1<= cos (m!*pi*x)<= 1, take powers of 2n on all sides and take limit as n goes to infinity, we get the limit of the original function as 1. Is that correct? I am not sure how to deal with the part where m goes to infinity.
Are you sure that you're supposed to take the limit as m tends to infinity last? The order will make a difference in how the problem works out.
No, that's not correct. Suppose m=1 and x=1/2. What would be the limit as n→∞? How about if x=1/3 instead?
I see your point. The limit varies as we vary m and x, but I am still stuck. So do we just say that there is no limit because the cosine function keeps oscillating between -1 and 1? I still have no clue how to deal with the m!
Like I said, the order of the limits matters. When you take the limit as n tends to infinity, you're doing so for a fixed m. And then you take the result of that and see what happens when m goes to infinity.
Could you please show me how you would do the problem? I have tried a variety of things like converting cosine squared into sine squared, or using e^ln form, but nothing seems to work. I am sorry, I am completely blank.
I don't think you did actually, because I gave you the wrong examples. :redface:
Say m=1. What's the limit equal to when x=1 as n→∞? What's the limit equal to when x=1/3? You should be able to convince yourself there are only two possible outcomes for the inner limit. Which one you get depends on m and x.
Okay let's do it the way you suggest. When m=1, x=1, then cos(pi)^2n=1 as n→∞. When m=1, x=1/3, then cos(pi/3)^2n= (sqrt3/ 2)^infinity = 0. So the two possible outcomes are zero and 1. So since m is an integer, it all comes down to x. If x=integer, then the limit is 1 and if x=/ an integer, then the limit is 0. Am I right yet?
Of course, if m=x, then we will have the limit as 1.
What if x=1/12? Is the limit always 0 regardless of the value of m?
What is the limit of cosine as x approaches infinity?
The limit of cosine as x approaches infinity is undefined. This is because cosine oscillates between -1 and 1 as x increases, and there is no single value that it approaches.
What is the limit of cosine as x approaches 0?
The limit of cosine as x approaches 0 is 1. This is because as x gets closer to 0, cosine also gets closer to 1, and they become indistinguishable.
How do I calculate the limit of cosine?
The limit of cosine can be calculated using the limit definition, where you take the limit as x approaches a specific value (such as infinity or 0) and plug it into the cosine function. Alternatively, you can use trigonometric identities and algebraic manipulation to simplify the expression and find the limit.
What does the limit of cosine represent?
The limit of cosine represents the value that cosine approaches as the input (x) approaches a certain value. It can also be interpreted as the horizontal asymptote of the graph of cosine.
Is the limit of cosine always defined?
No, the limit of cosine is not always defined. It depends on the value that x is approaching. If x approaches a value where cosine oscillates between -1 and 1, the limit will be undefined. However, if x approaches a value where cosine approaches a specific number (such as 0 or infinity), the limit will be defined.
