Lorentz Force Law - Tensorial Form
In summary, the Lorentz Force Law, \frac{dp^{\nu}}{d \tau} = -q U_{\mu} F^{\mu \nu}, is consistent with P^\mu P_\mu= -m^2. This can be seen by using the relation p = mU to show that the left-hand side expression is equal to zero, given the symmetry properties of the right-hand side. This shows that the law is consistent with a fixed mass.
Dewgale
98
Show that the Lorentz Force Law, [itex]\frac{dp^{\nu}}{d \tau} = -q U_{\mu} F^{\mu \nu}[/itex], is consistent with [itex]P^\mu P_\mu= -m^2.[/itex] Here U is the 4-velocity, F is the Electromagnetic Tensor, and p is the 4-momentum. (Minkowski Space)
As stated above.
I initially tried differentiating [itex]p^\nu p_\nu = -m^2[/itex] w.r.t. tau. This gave me, through the product rule,
[tex]p_\nu \frac{d p^\nu}{d \tau} + p^\nu \frac{d p_\nu}{d \tau} = 0 [/tex]. Since the only difference between the covariant and contravariant forms of the Lorentz Force Law is whether the [itex]\nu[/itex] on the F is raised of lowered. Substituting the Lorentz Force Law into the above, we get:
[tex] -q ( U_\mu F^{\mu \nu} p_\nu + U_\mu F^\mu_\nu p^\nu) = 0 [/tex]
-q cancels, leaving
[tex] ( U_\mu F^{\mu \nu} p_\nu + U_\mu F^\mu_\nu p^\nu) = 0 [/tex]
This is where I'm stuck. Both the left hand term and the right hand term are constants, and if I showed that one was the negative of the other I'd probably be set, but I'm not sure where to go from here.
Thanks!
First off, the metric is constant. What does this tell you about the derivative ##dp^2/d\tau##?
Hint: use the fact that you can raise and lower indices using the metric.
Second, what is the 4-momentum expressed using the mass and 4-velocity?
Well, first off, considering that [itex] p^2 = p^\mu p_\mu = \eta_{\mu \nu} p^\mu p^\nu = m^2[/itex], the constancy of the metric just tells me that the derivative is zero.
I suppose what I could do is take advantage of the fact that [itex] p_\nu = \eta_{\nu \alpha} p^{\alpha} = m \eta_{\nu \alpha} U^\alpha [/itex], and also of the fact that [tex] U^{\mu}U_{\mu} = -1[/tex], but I'm not sure of exactly how that would work with the indices.
I suppose what I could do is take advantage of the fact that [itex] p_\nu = \eta_{\nu \alpha} p^{\alpha} = m \eta_{\nu \alpha} U^\alpha [/itex], and also of the fact that [tex] U^{\mu}U_{\mu} = -1[/tex], but I'm not sure of exactly that would work with the indices.
EDIT: oops! Accidental double post. I can't seem to delete it, so if someone with that ability could do that, that would be nice. Thanks.
No it doesnt. It also tells you something about the form of the derivative regardless of the fact that p^2 = m^2.
I've got to admit, I'm very confused. If I add the metric in, the form of [itex]\frac{\partial p^2}{\partial \tau}[/itex] is [tex]\frac{\partial p^2}{\partial \tau} = \frac{\partial \eta_{\mu \nu} p^\mu p^\nu}{\partial \tau} = \eta_{\mu \nu} p^\mu \frac{\partial p^\nu}{\partial \tau} + \eta_{\mu \nu} p^\nu \frac{\partial p^\mu}{\partial \tau}. [/tex]
This can be re-written as [tex]\eta_{\mu \nu} p^\mu f^\nu + \eta_{\mu \nu} p^\nu f^\mu...[/tex]
Or as [itex] 2 p_\mu f^\mu = -q U_\nu F^{ \nu \mu} p_{\mu} = 0. [/itex]
I sort of just figured it out while typing. I feel like I'm probably (big if) on the right path now. Thank you!
Right (apart from a factor of two in the middle step). Now you can use the relation ##p = mU##. What does the result tell you?
Edit: Note that what you want to show is that left-hand side expression is equal to zero given the Lorentz force (otherwise it is incompatible with a fixed mass). Do not go around assuming that this is the case for the Lorentz force, you have to show it!
I get [itex] m U_\mu f^\mu = -q m U_\nu F^{\nu \mu} U_\mu [/itex]. Looking just at the left hand side, we can see that [tex] m U_\mu f^\mu = m (f^0 U_0 + f^i U_i) = m(\frac{\partial E}{\partial \tau} \gamma + \frac{\partial E}{\partial \tau} \gamma^{-1}) = m \frac{\partial E}{\partial \tau} (\frac{\gamma^2+1}{\gamma})[/tex]
However, in an object's rest frame, [itex]\frac{\partial E}{\partial \tau} = 0[/itex] I believe, due to conservation of energy. Therefore, the left hand side of the equation is equal to zero, showing that the law is consistent.
You are seriously overthinking this problem. Just look at the symmetry properties of the right-hand side.
Also, what you want to show is that the right-hand side is equal to zero. That the left-hand side is follows from ##p^2## being a constant.
1. What is the Lorentz Force Law - Tensorial Form?
The Lorentz Force Law - Tensorial Form is a mathematical equation that describes the force exerted on a charged particle in an electromagnetic field. It takes into account both the electric and magnetic fields, and is a tensorial form of the more commonly known Lorentz Force Law.
2. How is the Lorentz Force Law - Tensorial Form different from the traditional Lorentz Force Law?
The traditional Lorentz Force Law only accounts for the force exerted on a charged particle by an external magnetic field. The Tensorial Form takes into account both electric and magnetic fields, making it a more comprehensive equation.
3. What is a tensor and how is it used in the Lorentz Force Law - Tensorial Form?
A tensor is a mathematical object that represents a physical quantity in multiple dimensions. In the Lorentz Force Law - Tensorial Form, tensors are used to describe the electric and magnetic fields, as well as the force exerted on the charged particle.
4. How is the Lorentz Force Law - Tensorial Form used in scientific research?
The Lorentz Force Law - Tensorial Form is used in a variety of scientific research areas, such as particle physics, plasma physics, and astrophysics. It is also important in practical applications, such as designing electromagnetic devices and understanding the behavior of charged particles in magnetic fields.
5. Are there any limitations to the Lorentz Force Law - Tensorial Form?
Like any mathematical equation, the Lorentz Force Law - Tensorial Form has its limitations. It assumes that the charged particle is moving in a vacuum and does not take into account other factors, such as the particle's spin or its interactions with other particles. It is also a classical equation and does not account for quantum effects.
