Why does a microwave oven heat food faster than a black body?
In summary, the conversation discusses the differences in wavelength and frequency between visible light and microwaves, and how this affects the absorption of energy by different materials. It is explained that the intensity and number of photons play a role in the amount of power absorbed by a material, and this is why a painted black body does not heat up as much as water in a microwave. The conversation also mentions the intensity of electromagnetic waves in a microwave compared to the sun.
fluidistic
261
First of all I'm not sure this thread should be in this section or in the Thermodynamics one.
I don't understand something. If I'm not wrong, the wavelength of photons used in microwave oven cooking is around [tex]122 mm \sim 10^{-1} m[/tex], much greater than visible light photons (450 to 750 nanometers, from my memory, which is about [tex]5x10^{-6}m[/tex]. So the frequencies of micro wave is much lesser than the one of visible light. Since [tex]E_{\text{photons}}=h \nu[/tex] where [tex]\nu[/tex] is the frequency, it means that photons of visible light are much energetic than the microwave's ones, in fact by a factor of [tex]10^5[/tex]. I've heard that food (especially the ones containing water) can be cooked by microwaves because the wavelength of the waves "matches" the water molecules or so (though I don't understand this since it's they are at a totally different scale) and they enter in resonance so that in fact water molecules absorbs well the microwave. So far so good.
Now comes my problem. If I paint anybody of black so that it absorbs say around 70% of visible light, how come it doesn't heat much more than water in a microwave? Photons of visible light are so much more energetic and are mostly absorbed by the material (by its surface at least) that I can't understand why the painted "black" body doesn't heat up more than water in a microwave.
I know Stefan-Boltzmann's law of radiation so I can understand that a black body wouldn't heat that much because it also emits part of what it absorbs... but what happens in the microwave, I have no idea.
Science news on Phys.org
You have to take into account both, the energy of the photons and the number of them in order to calculate the amount of power absorbed.
The power of a normal microwave is around 1.5 kW, which would correspond to the power from the sun over a surface of 1 m^2. I guess that if you can concentrate all this power into a glass of water it will get hot too.
Actually there, it is being used already: http://en.wikipedia.org/wiki/Solar_cooker"
(emphasis added)
Because these are two quite different parts of the electromagnetic spectrum (as you seem aware). There's no reason to assume that something more absorbing in one area of the spectrum is more absorbing of radiation in other areas; radiation from different regions of the spectrum cause different physical effects. (which is in fact more or less how the different regions are characterized, with the natural exception of the visual range)
After all, a black radio doesn't get worse reception than a white one.
Thanks for the replies!
So it means that, if I'm not wrong, the intensity of EM waves inside a microwave is about 10^5 the one on Earth caused by the Sun.
alxm said:
(emphasis added)
Yes exactly. Water seems to absorbs microwave and not much visible light. That's why it needs so many photons to heat up since microwaves photons caries only [tex]10^{-5}[/tex] times the energy of visible light photons. On the other hand, a painted black body will absorbs light in the visible spectrum at least (and maybe even microwaves, I don't really know) and so it needs [tex]10^{-5}[/tex] times less photons to heat up compared to water, approximately. That's my understanding now... I hope it's right.
I am not sure what you mean by that. The number of photons per second to get the same power will be 10^5 times larger in the microwave frequency than for visible light.
What I meant is that the energy of all the sun light photons incident on a surface of 1 m^2 will be equal to the energy of all the photons in the microwave. The number of photons will not be equal though.
Yes that's what I meant in
fluidistic said:
Water seems to absorbs microwave and not much visible light. That's why it needs so many photons to heat up since microwaves photons caries only LaTeX Code: 10^{-5} times the energy of visible light photons. On the other hand, a painted black body will absorbs light in the visible spectrum at least (and maybe even microwaves, I don't really know) and so it needs LaTeX Code: 10^{-5} times less photons to heat up compared to water, approximately.
. I get it, thanks a lot! I think the intensity of light is directly proportional to the number of photons hitting a given area. So in a microwave, the intensity is roughly [tex]10^5[/tex] times greater than the light coming from the Sun, on Earth. (Assuming that the surface area of a microwave is of the order of a square meter, which seems to be OK).
It wouldn't occur to me to heat up food with photons [tex]10^{-5}[/tex] times less energetic than visible light's ones because of the intensity required. It seems interesting to learn how a microwave works. Specially how does it get a so big intensity. I'll read some information.
Question answered. Thanks guys.
My understanding is that infrared heat doesn't penetrate the surface of food. Microwaves, however, somehow do penetrate and vibrate the water molecules, thereby heating the food anywhere it is moist. So with a conventional (infrared) oven, much of the radiation is getting reflected off the food while conduction is taking place to get the heat from the outside to the inside of whatever you're cooking. I guess microwave cooking goes so fast because you don't have to deal with (as much?) reflection and conduction. I may not be completely correctly interpreting the book I read, though. I also, for example, don't get why microwaves interact with water molecules in particular when their wavelengths are from something like 3mm to 30cm (I forget the exact range). It does make sense that they don't penetrate the atmosphere, though, since they must get absorbed by water vapor before making it to the ground.
Yes, food is opaque to infrared, and less opaque to microwaves. So the microwaves penetrate straight through the food and heat it evenly. The main reason this is faster is that it allows you to use higher power. With ordinary heating you're limited by the fact the surface will start to burn.
Microwaves interact with molecules that have an electrical dipole moment. (such as water) The varying electric field of the radiation causes them to re-orient themselves with it - causing molecular motion, i.e. heat.
What is a microwave oven?
A microwave oven is a kitchen appliance that uses electromagnetic radiation in the microwave frequency range to heat and cook food. It works by emitting microwaves that cause water molecules in food to vibrate, creating friction and generating heat.
What is a black body in relation to a microwave oven?
A black body is a theoretical object that absorbs all radiation that falls onto it and emits thermal radiation based on its temperature. In the context of a microwave oven, the black body refers to the interior walls of the oven, which are designed to absorb the microwaves and distribute the heat evenly throughout the cooking chamber.
How does a microwave oven heat food?
A microwave oven heats food by emitting microwaves that cause water molecules in the food to vibrate, creating friction and generating heat. This heat is then transferred to the entire food item, cooking it from the inside out.
What is the role of the turntable in a microwave oven?
The turntable in a microwave oven helps to distribute the microwaves evenly throughout the cooking chamber. It also ensures that the food is exposed to the microwaves from all angles, resulting in more even cooking and preventing hot spots.
Are there any safety concerns with using a microwave oven?
While microwave ovens are generally considered safe to use, there are a few safety precautions to keep in mind. It is important to only use microwave-safe containers and avoid heating certain foods, such as eggs or grapes, which can explode. It is also recommended to avoid standing too close to the microwave while it is in use, and to never operate it with an empty cooking chamber.
9K
  • Electrical Engineering
