sonutabitha
- 8
I was searching for 24 micron counterparts(in the MIPSGAL catalogue) for Methanol Multibeam sources but found them missing for most of the cases. What could be the posssible reason?
The 24 micron counterparts for methanol multibeam sources are important because they provide valuable information about the physical properties and evolution of these sources. They can also help us understand the mechanisms behind the production of methanol in these sources.
The absence of 24 micron counterparts can significantly impact our understanding of the physical processes and conditions in these sources. It may also indicate that there are other factors at play, such as a lack of dust or a different mechanism for producing methanol than previously thought.
There could be several reasons for the absence of 24 micron counterparts. It could be due to a lack of sensitivity in the observations, contamination from other sources, or a different physical environment than expected. Further research is needed to determine the exact cause.
One potential solution is to use higher sensitivity instruments or observe at different wavelengths to try and detect the missing counterparts. It may also be helpful to compare with similar sources or conduct theoretical studies to better understand the physical conditions of these sources.
The absence of 24 micron counterparts raises new questions and challenges for future research in this field. It highlights the need for more comprehensive observations and theoretical studies to fully understand the nature of methanol multibeam sources and their physical properties. It also highlights the importance of considering all possible factors and sources of uncertainty in scientific research.
