Moment of inertia tensor of hollow cone
In summary, the homework statement is to find the moment of inertia for a uniform, thin hollow cone, such as an ice cream cone, of mass M, height h, and base radius R, spinning about its pointed end. The equation for the moment of inertia is I_{zz}=\sum x^{2}+y^{2}. The attempt at a solution is to first think of this as a bunch of little rings, area = 2\pi\rho dz, and then use the volume formula V= \frac{π h(a^{3}-b^{3})}{(3a}. However, the answer for a thin walled cone is not correct and does not reduce to the equation.
Lawrencel2
82
Find the inertia tensor for a uniform, thin hollow cone, such as an ice cream cone, of mass M, height h, and base radius R, spinning about its pointed end.
[itex]I_{zz} = \sum x^{2}+y^{2}[/itex]
[itex]\rho = \sqrt{x^{2}+y^{2}}[/itex]
I first tried to think of this as a bunch of little rings
[itex]area = 2\pi\rho dz[/itex] as rho is changing as height increases
i defined rho as [itex]\rho=\frac{z R}{h}[/itex]
but how would i set up this integral? My book shows a few examples of doing it with a solid but i don't know how to do it with an area. so far i have
[itex]\int \frac{2\pi R^{3}}{h^{3}} z^{3}dz[/itex]
I know that that the [itex]I_{zz}= \frac{MR^{2}}{2}[/itex] just need help getting started
Hi Lawrencel2! :smile:
they aren't little rings, they're little volumes, all at a distance r from the axis, and with thickness t and height dr*R/h :wink:
Another way to think about the moment of inertia of a conical shell is this: If the thickness of the shell is infinitesimally small then the rings do not overlap. This is just like splitting a solid disc up unto little rings. As Lawrencel2 mentioned, the moment of inertia of the hollow cone is MR^2/2, which is also that of a solid disc.Now here's my problem. How does one do this when the walls of the cone are not thin (say inner radius b and outer radius a)?
First, I'd like to explain how I did this for a hollow sphere because I think the same approach should work here.
My approach for the sphere was to change the limits for the radius to be from b to a instead of from 0 to R. When the integration is said and done you end up with
[itex]I_{zz}[/itex]=[itex]\frac{2M(a^{5}-b^{5})}{5(a^{3}-b^{3})}[/itex]
This can be factored to give
[itex]I_{zz}[/itex]=[itex]\frac{2M(a^{4}+a^{3}b+a^{2}b^{2}+a b^{3}+b^{4})}{(a^{2}+ab+b^{2})}[/itex]
If you then let the inner radius b equal the outer radius a you will get the familiar result that a thin hollow sphere has MoI equal to 2/3MR^{2}
Now, the same approach for the hollow cone. Its the same set up for a solid cone
Integrate[[itex]r^{3} dr d[/itex][itex]\phi[/itex] dz] using cylindrical polar coordinates, but now the limits on r will be from bz/h to az/h.
I end up with [itex]\frac{1}{10}[/itex] [itex]\rho[/itex] [itex]π h(a^{4}-b^{4})[/itex]
Where [itex]\rho[/itex] is the density and h is the height. Plugging in M/V for the density I get (the volume of a conical shell is V= [itex]\frac{π h(a^{3}-b^{3})}{(3a}[/itex]
[itex]\frac{3 M a}{(a^{3}-b^{3} π h}[/itex] [itex]\frac{1}{10}[/itex] [itex]\rho[/itex] π h[itex](a^{4}-b^{4})[/itex]
or
[itex]\frac{2Ma(a^{3}+a^{2}b+a b^{2}+a b^{3})}{(a^{2}+ab+b^{2})}[/itex]
By the way, how the heck does this volume formula V= [itex]\frac{π h(a^{3}-b^{3})}{(3a}[/itex] for a cone come about?! I looked it up and I'm puzzled by it.This answer is not correct and does not reduce to the thin conical shell The correct expression for the MoI (assuming Wolfram Alpha is correct) is
[itex]\frac{3(a^{5}-b^{5})}{(10(a^{3}-b^{3})}[/itex]
Which does reduce to the correct thin walled answer.
Can anyone point out where my mistake(s) are?
Another question: how can I correctly set up the other moment of inertia integrals [itex]I_{xx}[/itex] and [itex]I_{yy}[/itex] (they will be the same because of the symmetry) for a hollow cone? I have no problem doing this if the cone is solid, but I'm having trouble figuring it out for a hollow one.
Thanks in advance!
To find the moment of inertia tensor for a hollow cone, we can use the parallel axis theorem, which states that the moment of inertia of a body about an axis is equal to the moment of inertia of the body about a parallel axis through its center of mass, plus the product of its mass and the square of the distance between the two axes. In this case, the cone is spinning about its pointed end, so the parallel axis theorem can be written as:
I_{zz} = I_{cm} + Md^{2}
Where I_{zz} is the moment of inertia about the pointed end, I_{cm} is the moment of inertia about the center of mass, and d is the distance between the two axes.
To find I_{cm}, we can use the formula for the moment of inertia of a thin hollow cone about its central axis, which is given by:
I_{cm} = \frac{3MR^{2}}{10}
To find d, we can use the Pythagorean theorem to calculate the distance between the pointed end and the center of mass. Let's call this distance h_{cm}. Using the given height and base radius, we can calculate h_{cm} as:
h_{cm} = \sqrt{R^{2} + \frac{4h^{2}}{9}}
Now, we can substitute our values into the equation for the parallel axis theorem and solve for I_{zz}:
I_{zz} = \frac{3MR^{2}}{10} + M\left(\sqrt{R^{2} + \frac{4h^{2}}{9}}\right)^{2} = \frac{3MR^{2}}{10} + M\left(R^{2} + \frac{4h^{2}}{9}\right) = \frac{3MR^{2}}{10} + MR^{2} + \frac{4Mh^{2}}{9} = \frac{13MR^{2}}{10} + \frac{4Mh^{2}}{9}
Therefore, the moment of inertia tensor for a hollow cone spinning about its pointed end is:
I = \begin{pmatrix} \frac{13MR^{2}}{10} + \frac{4Mh^{2}}{9} & 0 & 0 \\ 0 & \frac{13MR^{2}}{
1. What is the moment of inertia tensor of a hollow cone?
The moment of inertia tensor of a hollow cone is a mathematical representation that describes the distribution of mass and its resistance to rotation around different axes. It takes into account the shape, size, and mass distribution of the cone in order to calculate its moment of inertia.
2. How is the moment of inertia tensor calculated for a hollow cone?
The moment of inertia tensor for a hollow cone can be calculated by using the formula I = (3/10)mr^2, where m is the mass of the cone and r is the radius of the base. This formula takes into account the shape and mass distribution of the cone in order to determine its moment of inertia.
3. What is the significance of the moment of inertia tensor for a hollow cone?
The moment of inertia tensor is an important concept in physics and engineering as it helps us understand the rotational behavior of objects. For a hollow cone, the moment of inertia tensor can tell us how difficult it is to rotate the cone around different axes, and how the cone will respond to external forces and torques.
4. How does the moment of inertia tensor change for different types of hollow cones?
The moment of inertia tensor can vary for different types of hollow cones depending on their size, shape, and mass distribution. For example, a cone with a wider base will have a larger moment of inertia tensor compared to a cone with a narrower base, as the mass is distributed further from the axis of rotation.
5. What are some real-world applications of the moment of inertia tensor for a hollow cone?
The moment of inertia tensor for a hollow cone has various applications in physics and engineering. It is commonly used in the design and analysis of rotating machinery, such as turbines and propellers. It is also important in understanding the stability of objects in motion, such as spinning tops or gyroscopes. Additionally, the moment of inertia tensor can be used in the study of celestial bodies, such as planets and stars.
11K
