Need explanation on convergent
In summary, the conversation is discussing the concept of convergence in numerical ordinary differential equations, specifically in relation to iterative methods used to solve them. The wiki reference explains that convergence is necessary for a method to be considered useful, as it ensures that the sequence of functions generated by the method will ultimately approach a true solution. Without convergence, the method is not a reliable way to approximate a solution.
convergence in a laymans language means tending towards a certain point for e.g if you consider the sequence 1/n and take values for n you get 1,1/2,1/3...0 the sequence converges to 0 i.e to mean ⅟∞=0...
I think the specific reference you are referring to is
All the methods mentioned above are convergent. In fact, convergence is a condition sine qua non for any numerical scheme.
This section is referring to numerical methods to solve a differential equations by "iterative" methods- finding one function after another hopefully getting closer and closer to a true solution. That is saying that the sequence of functions converges to a true solution. It might be that a sequence of functions given by a particular method converges very slowly to a true solution (so it's not a very useful method) or that, no matter how many terms you take it is still slightly off a true solutions (taking higher and higher terms in Fourier series around a point at which the function is not continuous will always "miss" the function in some neighborhood of that point- the neighborhood gets smaller, but the "error" never goes to 0. See "Gibbs phenomenon")
However, whether a sequence of functions converges slowly or slightly misses a true solution, it might still be a useful method for some purposes. If, on the other hand, the sequence does not converge at all, it can't possibly be a useful method for finding a solution, even approximately! That is why convergence is a "sine qua non" ("without which, not") to even consider an interation method. Without at least convergence, it can not be a good method!
Related to Need explanation on convergent
What is convergent?
Convergent is a term used in science to describe a process where two or more things come together to form a single point or outcome. It can refer to physical objects or ideas.
What is the difference between convergent and divergent?
The main difference between convergent and divergent is that convergent refers to things coming together while divergent refers to things moving apart. Convergent is associated with unity and convergence, while divergent is associated with divergence and separation.
What are some examples of convergent evolution?
Convergent evolution is when two unrelated species develop similar features or traits due to similar environmental pressures. Examples include the wings of bats and birds, which evolved separately but serve the same purpose for flight, and the streamlined bodies of sharks and dolphins, which allow for efficient swimming in water.
How does convergent thinking differ from divergent thinking?
Convergent thinking is a cognitive process that involves narrowing down a set of options or ideas to find the best solution or answer. Divergent thinking, on the other hand, is a process of generating multiple ideas or solutions to a problem. Convergent thinking is more focused and analytical, while divergent thinking is more exploratory and open-ended.
Why is convergent evolution important in understanding biodiversity?
Convergent evolution is important in understanding biodiversity because it shows how different species can adapt to similar environments and challenges. It highlights the role of natural selection in shaping the diversity of life on Earth and helps us understand the relationships between different species and their environments.
  • Differential Equations
