Nuclear reaction cross section
In summary, the average time for a given nucleus in a thin target to suffer a neutron interaction with an intensity of 10^12 neutrons/(cm^2.s) and a total cross section of 4 b would be approximately 7.9 years. However, this time may vary depending on experimental conditions and other factors.
thenewbosco
187
Suppose we consider a beam of neutrons incident upon a thin target with an intensity of 10^12 neutrons/(cm^2.s). Suppose further that the total cross section for the nuclei in this target is 4 b. Using this information, determine how long one would have to wait, on the average, for a given nucleus in the target to suffer a neutron interaction.
The way i approached this is to get a rate from Intensity*cross section = rate
this gives
10^12 neutrons/(cm^2 sec) * 4.0 × 10^-24 cm^2 = 4 × 10-12 s^-1
Then taking 1/rate should give the length of time...but this gives an extraordinarily long time of course which leads me to believe something is wrong?
how should this be approached
Thank you for your question. Your approach is correct, but there are a few things to consider in order to get a more realistic answer.
First, the intensity of 10^12 neutrons/(cm^2.s) is quite high, and it is more common to use a lower intensity in neutron experiments. This is because high intensity beams can cause damage to the target material and can also lead to multiple interactions occurring at the same time, making it difficult to determine the exact interaction time for a single nucleus.
Second, the cross section for neutron interactions can vary depending on the energy of the neutrons and the specific target material. So, the value of 4 b may not be accurate for all situations.
With that being said, let's assume that the intensity and cross section given in the question are accurate for our scenario. As you correctly calculated, the rate of neutron interactions would be 4 × 10^-12 s^-1. This means that on average, one interaction would occur every 1/(4 × 10^-12) = 2.5 × 10^11 seconds, or approximately 7.9 years. This is a long time, but as mentioned before, it is due to the high intensity and simplified assumptions used.
In reality, the interaction time for a given nucleus would depend on many factors, such as the specific energy and direction of the neutron, the location and orientation of the nucleus in the target, and the properties of the target material. These factors can be taken into account through more advanced calculations and simulations.
I hope this helps clarify the concept of interaction time for a given nucleus in a neutron beam. Keep in mind that the actual time may vary depending on the specific experimental conditions. Thank you for your question and happy experimenting!
1. What is nuclear reaction cross section?
Nuclear reaction cross section is a measure of the probability that a given nuclear reaction will occur between two particles when they collide. It is typically denoted by the symbol σ and is measured in units of area.
2. How is nuclear reaction cross section calculated?
Nuclear reaction cross section is calculated by using the principles of quantum mechanics and the properties of the particles involved in the reaction, such as their energies and masses. It is also influenced by the structure of the nuclei and the strong and weak nuclear forces.
3. What factors affect nuclear reaction cross section?
The factors that affect nuclear reaction cross section include the energy of the colliding particles, the nuclear structure of the target and projectile particles, the angular momentum of the particles, and the presence of any electromagnetic or nuclear forces.
4. What is the significance of nuclear reaction cross section?
Nuclear reaction cross section is an important parameter in nuclear physics as it helps in understanding the fundamental interactions between particles and the structure of the nucleus. It is also used in nuclear engineering for designing and predicting the behavior of nuclear reactors and other applications of nuclear energy.
5. How is nuclear reaction cross section experimentally determined?
Nuclear reaction cross section is experimentally determined by performing controlled collisions between particles and measuring the resulting products. This can be done using techniques such as particle accelerators, nuclear reactors, and scattering experiments. The data obtained from these experiments is then used to calculate the cross section values.
  • Science Fiction and Fantasy Media
