Offshore oil drilling is safe?
  • News
  • Thread starter MotoH
  • Tags
    Oil
In summary, an explosion at a drilling rig off the coast of Louisiana has created a large oil spill. It is still unclear how the spill will be stopped, and the safety of the workers is still a concern.
  • #421
  • #422
mheslep said:
In the CNN video/phone interview at 1:58 Wereley says 70,000 gallons per day, and he says it twice. No doubt he meant barrels, as does CNN's Cooper who corrects himself.
http://ac360.blogs.cnn.com/2010/05/14/must-see-ac360°-video-oil-spill-worse-than-expected/
I've still not seen a single word about the composition of the material coming out of that pipe.
I've looked a lot, and the only information out there is "a mixture of LSC and Natural Gasses." I guess we can rest assured that methane is present, but the behavior of these oil "plumes" is odd. I wonder if it has to do with pressure, temp, dispersant usage, or a result of another element in the mix.
It certainly appears to be LSC being blasted by its own pressure and the release of NG.
  • #424
I'm kinda thinking of the biblical/mayan prophecys on this one... Though something like this was bound to happen given our technological ignorance as a race. On the plus side this could actually end up being a good thing in a weird way I won't even hint at.
  • #425
I was in the car yesterday and heard a news report in which BP claimed to be recovering 20% of the oil spewing from the big leak. I turned to my dog (a good listener) and said, they're getting maybe 1000 bbl/day and pretending that their fantasy 5000 bbl/day estimate is real. Sure enough. Today, BP released more video, and the prof who estimated 70,000 bb/day (20% error range) has studied the clips and now says that his estimate was WAY low.
  • #426
Great... that's less than comforting.
  • #427
turbo-1 said:
...and the prof who estimated 70,000 bb/day (20% error range) has studied the clips and now says that his estimate was WAY low.
70,000 bbl of what?
  • #428
clean water.
  • #429
mheslep said:
70,000 bbl of what?
LSC and NG.
  • #430
Congress pressured BP into releasing more videos today. Wereley says that based on the latest videos, his first impression is that the leak is signficantly larger than the 70,000 barrels per day, first estimated.
http://www.msnbc.msn.com/id/3032619/#37220532
[the videos are the only link up at the moment]
Tar balls have begun to wash ashore in Florida. They are being analyzed to see if they could be from the BP spill. Most people apparently think it is too soon - time and distance - to be seeing tar in Florida.
What may be large underwater plumes of oil have been detected, that are also being tested. Yesterday, one plume was estimated to be about 20 milles x 5 miles x 300 feet, in size. I think they said this was detected at a depth of about 1200 feet. This may explain the apparent conflict between the satellite-based estimates, based on the size of the visible plume, and the rate suggested by the Purdue velocimetry analysis.
Late Edit: Name/spelling
  • #431
Ivan Seeking said:
Congress pressured BP into releasing more videos today. Worley says that based on the latest videos, his first impression is that the leak is signficantly larger than the 70,000 barrels per day, first estimated.
Plumes are thanks to the liberal use of dispersants... idiots. They are poisoning the entire water column. Birds may not look as miserable as in the Exxon-Valdez, but this is already eclipsing that in terms of likely damage to marine environments.
  • #432
I don't think the exxon valdez can compair to this honestly. Does anyone have any information on how big the oilfield that is fueling this is? I tryed to find some info on it for a lil bit but wasn't finding anything. I assume the oil companys keep it a secret anyhow...
  • #433
What does "significantly" mean? Is his new estimate inside or outside the 20% error margin he he claimed for his first estimate?
  • #434
It's like 15 times it.
Basically an entire oilfield is emptying into the ocean. I just kinda wonder if it's part of the oilfields that run from africa to america. I find it hard to believe they are completely connected but who knows.
  • #435
He clearly wanted to avoid any specific statements until an official analysis is done, but he made it clear that the 70k bpd estimates appear to be too low; without even doing an analysis! I think that's all we get for now.
  • #436
Could be, perhaps, but I don't think that is a given. I would imagine that it was too far down. Based on the confidence of the Purdue team, it seems to me more likely we have 70k+ bpd leaking, so the oil has to be going somewhere. It sounds like plumes might get getting trapped between thermal layers. Either way, we don't know for certain if it's oil yet. The recovery team sounded pretty confident, but the analysis isn't in yet, afaik, Presumably, the analysis would show if it is oil that has been treated.
  • #437
If you haven't seen this yet it's worth a look.
  • #438
Since we're still pretty sketchy on the details of his method and this statement by him seems odd in the context of his previous estimate and accuracy claim, I've started a companion thread in Mechanical Engineering to discuss the nuts and bolts of how this works:
https://www.physicsforums.com/showthread.php?p=2723252#post2723252
  • #439
Not at all. One obviously tends to be very conservative when making any assumptions about something as big as this. Apparently he saw something suggesting that he was too conservative; significantly so. More video from multiple angles means more data. I don't find it surprising at all. What I do find surprising is that he would say anything without first doing the analysis. He must be pretty confident about what he sees. I doubt he would say anything if he thought it was only a 20% difference.
It may be that he got to see all three leaks today, instead of just a few seconds of video of one pipe. I think that is the case.
  • #440
Ivan Seeking said:
Not at all.
You don't think it is odd that he said his previous estimate was substantially low even though previously he said his estimate was accurate to within 20%? Seems like a contradiction to me: as if he's not as certain as he previously said he was.
No. "Conservative" here would mean providing a wide margin for error, not purposely underestimating the flow. No good scientist would purposely estimate low in a situation where such a bias isn't needed (such as in a safety-factor on building a bridge). Also, that's you saying that: he didn't say he purposely estimated it low before.
He seemed pretty confident in his previous claim! But yes - that is surprising.
But then, he is an expert.
Yes, which makes the contradiction in his statements all the more surprising.
  • #441
Really I just want to know how big the oilfield is I can answer most the questions I have my self once I get this info.
  • #442
Russ, the prof made his initial estimate based on one video from one POV, and he has said that that estimate is far too low. You can second-guess him all you like, but without some scientific basis for doing so, you sound like an echo for the right-wing media that is making BP's case on the news every night. "It's only 5000 barrels per day." "We're recovering 20% of the spill with the siphon." That's crap and you know it.
BP is in full damage control and we will never know the extent of this spill until federal regulators grow a pair and demand that BP releases all relevant information. There is a team from Woods Hole ready to hit the leak site, but BP (in its imperial capacity) has refused them access to the well (really?) saying that it is more important to stop the leak than to understand the leak and measure the extent of the leak. Since when does a company operating under a US drilling license get to restrict access to a US oceanographic company that needs to monitor their operations? Wave the flag all you want, Russ, and champion the rights of corporations. This spill proves the failure of the neo-con philosophy.
  • #443
Ya why is the person who makes the problem is the one in charge of fixing it?
  • #444
Haliburton caused the problem. They were hired to cap the well, but failed, which caused the explosion.
So, what do you mean?
  • #445
Natural oil seepage in the worlds oceans (nothing to do with evil human industrial activity and our will to live) is roughly the equivalent of an exxon valdez every year. The magnitude of this spill is irrelevant to the global environment in the big picture.
  • #446
Spin power
https://www.youtube.com/watch?v=e41Sq-ALDGk
  • #447
Why do you think it's spin, it's the obvious truth. You might call it opportunistic.
Also apparently BP was cutting corners.
  • #448
Restating the issue doesn't do anything to address the apparent contradiction.
I've never seen such a thing - could you give an example?
By failing to address the issue, you sound like you're making knee-jerk anti-corporate judgements without thinking through the issue. You guys are proving yourselves to be everything that you are accusing others of being! You're showing clear bias here in your treatment of the issue. This thread is just an excuse for people to spout anti-coroporate propaganda.
Agreed! (and until a full investigation finishes). So why latch on to uncertain predicitons as if they have certainty? (Answer: because you like them.)
I have no idea what you are talking about. I'm not sure you've been reading the right thread.
  • #449
It's a lot more complicated than that and it appears from what I have seen taht Haliburton has the least of the blame of the 3 companies involved.
  • #450
Do you have a source for that? I've never heard of it.
  • #451
russ_watters said:
Restating the issue doesn't do anything to address the apparent contradiction. I've never seen such a thing - could you give an example?
By failing to address the issue, you sound like you're making knee-jerk anti-corporate judgements without thinking through the issue. You guys are proving yourselves to be everything that you are accusing others of being! You're showing clear bias here in your treatment of the issue. This thread is just an excuse for people to spout anti-coroporate propaganda. Agreed! (and until a full investigation finishes). So why latch on to uncertain predicitons as if they have certainty? (Answer: because you like them.)
I have been reading this, and to someone who was not so keenly aware of your relentless pursuit of scientific purity, it would appear that you simply step into contradict and raise doubt without offering anything concrete of your own to do so. Of course, it is just that you wish to see the rules of PF followed to the letter, but it makes you sound like a shill for the various groups involved. Needless to say, this must not be the case, but it would be a refreshing change of pace to see you provide information, rather than simply urge a complete cessation of meaningful debate given limited information. If we did that, why, it could be a decade or two until the final analysis is in. :)
We do agree at least, that unless materials analysis of the shoe and cement shows a major defect, Haliburton, while its history is ugly, is possibly blameless.
Now, for examples of right-wing media, and how you sound like them both in terms of content and tone, why not read or watch some? You're concerned with how this "sounds", but this is hardly people flambeing a particular engineer after the Challenger, but rather reacting to the information that is available, and the information that is, pardon the pun, leaking bit by bit. I don't believe that you are an ideologue as Turbo-1 does, I believe you have fallen prey to what many engineers and others in practical applications of science do: you are tired of having the proverbial blood thrown on you as you leave the lab, and you now react rather than think. It is pitiable, and understandable, but for that reason perhaps you should not read what offends your sensibilities so greatly?
Your criticism of Ivan's presentation of Steven Wereley's results are just that, critique if his presentation. You ignore the expertise of Purdue, and the methods used.
Steven Wereley is the primary figure here, but there is some independent corroboration by Timothy Crone of Lamont-Doherty Earth Observatory, and Eugene Chiang, a professor of astrophysics at the University of California, Berkeley.
This is the old news, more have made similar estimates, and while your point that they vary is a true, NONE hold 5000 barells/day is anything, but a fond wish. again: http://www.npr.org/templates/story/story.php?storyId=126809525
Your response to Antiphon is interesting, but very nearly unique.
Magpies, the oil companies pay a great deal to gamble on a given region, and their estimates of well capacity are just that, estimates, and also proprietary. They would be insane to offer that info, then it cannot help matters; the pressure and the pipe and composition of the effluent and oil are the issues.
Emreth: People like birds, they don't have the same reaction for fish or larvae or shrimp. Yet, birds are far from being the first to feel the effects, nor the worst hit. This is spin, even if it is for an arguably good cause.
http://news.yahoo.com/s/afp/20100517/ts_alt_afp/usblastoilenergypollution
http://www.nytimes.com/gwire/2010/0...dril-likely-headed-into-loop-curre-32417.html
http://www.noaanews.noaa.gov/stories2010/20100518_closure.html
http://news.yahoo.com/s/nm/20100519/ts_nm/us_oil_rig_leak
Oh yes, and CNN is now showing the oil wash upon the Louisiana barrier islands. Thick oil now, not merely sheen, for a total of 20 miles of effected coastline.
Good news is that the tar balls found in the Florida Keys have been determined not to have come from the Deepwater Horizon leak.
  • #452
Eh I am not really worried about this honestly the problem will probably fix it's self. Heck if this goes on long enough all we will need to do to drive around is pour some sea water into the gas tank!
  • #454
No I was making a scientific paper...
  • #455
According to CBS news, a film crew attempting to get footage of a beach in South Pass was told to turn back or face arrest. The boat that blocked them was allegedly manned by BP contractors and two Coast Guard members. What is going on here?
http://www.cbsnews.com/video/watch/?id=6496749n&utm_source=feedburner&utm_medium=feed&utm_campaign=Feed:+CBSNewsVideoUS+(CBSNews.com%C2%A0Video:+US)
Obama's Teflon coating is going to evaporate if stuff like this continues. The Navy has a lot of very competent and well-equipped submersible ROV's and it's high time that they were employed in an attempt to stop these leaks. It is apparent that BP's "readiness" for dealing with deep-sea leaks is non-existent. We should try to do the job that they cannot and bill them for the entire cost, as well as the lost livelihoods related to the spill. If BP doesn't want to pay up and wants to fight, cancel all their leases.
  • Electromagnetism
24K
  • DIY Projects
  • Mechanical Engineering
  • General Math
  • Electrical Engineering
