- #736
russ_watters
Mentor
- 23,168
- 10,380
Here's a sketch of a relief well: http://rovicky.files.wordpress.com/2006/08/relief-well-2.jpg
A few components/differences:
1. The relief well doesn't actually go all the way into the reservoir (is there a reisk of not judging the depth correctly?) but rather intersects the main well.
2. Based on #1, obviously the relief well comes after the main well. They can be started and drilled more or less simultaneously, but the relief well has to be behind the primary well.
3. Once drilled and connected, you just have a two-outlet, headered-together set of pipes. At the top of each, they look absolutely identical and at the bottom where they join, the pressures are identical. Each has to have a blowout preventer on it and each carries similar risk of a blowout.
4. The point of the relief well is to do exactly what was supposed to be done with the primary well beforee the BP supervisor had the drilling "mud" removed from the well: Since the "mud" is heavy, it exerts pressure at the bottom to keep the oil and gas from being pushed-up by the pressure in the reservoir.
So what's the difference between the "top kill" and "bottom kill"? In a top kill, there are two big problems, neither condition existing for the "bottom kill":
1. The pipe pumping the "mud" into the well goes in the side of the BOP and the top of the BOP is open, so the "top kill" mud can just spill out the top of the well and onto the seafloor, relieving the pressure and not forcing the oil down. For the "bottom kill", if the "mud" goes up the maini well, it eventually just fills up the well and still ends up stopping the oil.
2. Since the "bottom kill" happens an extra couple of miles down, it has a lot more pressure above it to force the "mud" down and can also rely somewhat on the weight of the oil. Ie, the pressure differential at the bottom is smaller than it is at the wellhead.
