How Do Newton Rings Help Calculate Lens Curvature?
In summary, the conversation involved a Newton rings experiment where a lens was placed on a flat surface and the interference patterns created Newton rings. The diameter of the first five rings were measured and plotted on a graph of d^2 against N (number of the individual ring). From this, the slope and intercept of the graph was found, leading to an equation of y=0.0093x+0.0011. The first question asked for the radius of curvature of the lens, which was calculated graphically and using the formula d^2=4λrN+constant. However, a discrepancy in the decimal point led to an incorrect answer, which was later corrected to be around 39.5cm. The conversation also highlighted
bondgirl007
73
These are problems from a Newton rings experiment where a lens was placed on a flat surface and the interference patterns created Newton rings. I measured the diameter of the first five rings and then plotted a graph of d^2 against N (number of the individual ring).
These are my x and y values:
N D^2
1 0.011 mm
2 0.019 mm
3 0.029 mm
4 0.038 mm
5 0.048 mm
From this, I found the slope of the graph and the intercept of the line on the y-axis as I got an equation of y=0.0093x+ 0.0011. From this, I was told to graphically calculate r (radius of curvature of unknown lens) and then calculate r for each ring using the formula d^2 = 4 (lamba) r N + constant where lamba = 589.3 nm and the constant is the y-intercept.
This is what the first question is asking...
1. What is the radius of curvature of this lens? Show your results as separate calculations for each value of N. After doing this, I am required to calculate the power of the lens, assuming the refractive index of the lens is 1.523.
y=0.0093x+0.0011 which translates to...
d^2 = [4*lamba*r]N + b
F = n'-n/r (for power of the lens after finding r)
For the first part where it says graphically calculate r from the slope:
y=0.0093x + 0.0011
I am unsure how to get radius from this...
I tried:
9300 nm^2 = 4 (589.3 nm)(r)
r = 3.95 mm but this seems incorrect...
I would really appreciate help on this!
N D^2
1 0.011 mm
2 0.019 mm
3 0.029 mm
4 0.038 mm
5 0.048 mm
Please check the units of D^2 in that table.
Are these D^2 or D?
How did you measure to such a high level of accuracy?
Since you plotted D^2 vs N, you do not have x and y values. You have N and D^2 values. Your equation should be:
D^2=(0.0093)N+(0.0011) mm2
Never use generic variables.
Always include units.
What color corresponds to that wavelength?
Does that match the color you used?
So you compared the theoretical equation with the equation you determined experimentally.
you have
theory: d^2 = 4λrN + c
experiment: d^2 = (0.0093mm)N + (0.0011mm)
therefore: 4λr=?
I tried:
... that does seem a tad small. What sort of radius would be plausible?
Note: 0.0093mm2 ≠ 9300nm2
Thanks for your reply and tidying up my equation!
4λr should equal 0.0093 mm. I tried plugging it in as follows and still get the same answer..
0.0093 mm = 4(0.0005893mm)r
r= 3.95 mm
These measurements were obtained using a Vernier scale, thus they are to three decimal places.
The final answer, which is the surface power of the lens and obtained using the equation (n'-n)/R is around +1.5, which would mean the radius of curvature is around 0.35 m. I am not sure if my units are off with the decimals...
I think you have misplaced the decimal point - yes.
If 4λr=0.093mm, then r=39.5cm - which is the right order of magnitude.
A micrometer scale makes more sense for vernier calipers too.
For the future: you should make some effort to get a crude measurement (scientific estimate) for important properties as a kind-of reality check. The curve of the glass could have been traced, or you could work it out by rocking it and sighting the angle. This is stuff you learn from experience... it gets so you don't even notice yourself doing it half the time.
As a scientist, my response to this content would be as follows:
Firstly, it is important to note that the Newton rings experiment is a common method for determining the radius of curvature of a lens. It involves placing a lens on a flat surface and observing the interference patterns created by the light passing through the lens.
In this experiment, you have measured the diameter of the first five rings and plotted a graph of d^2 against N, where N is the number of the individual ring. From this, you have found the slope of the graph and the y-intercept, which can be used to calculate the radius of curvature of the lens.
To graphically calculate the radius of curvature, you can use the slope of the graph, which is equal to 4*lambda*r, where lambda is the wavelength of the light used (in this case, 589.3 nm) and r is the radius of curvature. From this, you can calculate the radius of curvature for each value of N using the formula d^2 = 4*lambda*r*N + b, where b is the y-intercept.
For the first question, you are asked to calculate the radius of curvature of the lens. Using the values given in the problem, you can calculate the radius of curvature for each value of N as follows:
For N = 1: d^2 = 0.011 mm = 0.000011 m
r = (0.000011 m - 0.0011)/(4*589.3 nm) = -0.000001 m = -1 um
For N = 2: d^2 = 0.019 mm = 0.000019 m
r = (0.000019 m - 0.0011)/(4*589.3 nm) = 0.000003 m = 3 um
For N = 3: d^2 = 0.029 mm = 0.000029 m
r = (0.000029 m - 0.0011)/(4*589.3 nm) = 0.000008 m = 8 um
For N = 4: d^2 = 0.038 mm = 0.000038 m
r = (0.000038 m - 0.0011)/(4*589.3 nm) = 0.000013 m = 13 um
For N = 5
1. What are Newton Rings?
Newton Rings are a phenomenon that occurs when light waves reflect and interfere between two curved surfaces, creating a series of concentric colored rings. This effect was first described by Sir Isaac Newton in the 17th century.
2. How do Newton Rings form?
Newton Rings form when a convex lens is placed on top of a flat glass surface. The air trapped between the two surfaces creates a thin film, and when light waves reflect off of this film, they interfere with each other, resulting in the formation of the rings.
3. What causes the different colors in Newton Rings?
The different colors in Newton Rings are caused by the varying thickness of the air film between the two surfaces. This thickness changes as the distance from the center of the rings increases, resulting in different colors being reflected at different points.
4. How can Newton Rings be used in scientific research?
Newton Rings have been used in various scientific research studies, particularly in the field of optics. They have been used to measure the refractive index of transparent materials, as well as to study the properties of thin films and interference patterns.
5. Can Newton Rings be seen in everyday life?
Yes, Newton Rings can be seen in everyday life in various objects such as soap bubbles, oil slicks, and even CDs and DVDs. They can also be observed when looking at a light source through a glass of water or a curved glass bottle.
13K
