Parallel Plates Capacitors, two capacitors.
In summary: This is also supported by the fact that the charge on plate S, Qs, is equal to the charge on plate T, Qt, meaning that the same amount of charge is spread out over a larger area in SU, resulting in a higher energy density.
Freddd3
1. I mostly just need help understanding 3 and 4. And also understanding how to tell if things drawn on a circuit diagram/sketch are parallel or in series. I have the correct answer already, but it was mostly just guessing for 3 and 4.
The sketch is a side view of two capacitors consisting of parallel plates in air. The capacitor plates are equal in area but the plate separation differs as shown. Indivudual capacitors are specified with two letters, for example TR is a single capacitor. The charge on plate T is represented by Qt. The capacitors are charged so that the potential (voltage) at A, VA, initially equals 25 volts. for each of the statements choose the proper response.
Sketch here: http://www.freeimagehosting.net/m9tjl
1) ______ Qt + Qr is ... zero.
2) ______ The electric field between plates T and R is ... that between plates S and U.
3) ______ If the plate separation for capactior SU increases, the energy stored in TR will ... .
4) ______ If the plate separation for capacitor SU decreases, the charge on Qt will ... .
5) ______ Qt is ... Qs.
6) ______ The energy stored in capacitor SU is ... the energy stored in capacitor TR.
2. C = ε0 * A / d
C = Q/V
V = d*Q/(ε0 * A)
E = Q/ (ε0 * A)
σ = Q/A
U = (1/2) * C * V2
3. I have the correct answers for all of these questions, but I don't know why.
1.
EQUAL TO. This one is clear, because by definition parallel plate capacitors have charges with equal magnitudes, but opposite signs.
2.
LESS THAN. My reasoning was that the voltage for each one should be the same. So E = VA/d is how I figured out the electric field for each one. "d" is larger for TR than SU, and the voltage and the area for both SU and TR are the same. So the E is smaller in TR than SU.
3.
INCREASE. Don't know why. C gets smaller as d gets larger, and U gets smaller as C gets smaller. I figured if energy isn't leaving the system, then the energy from SU has to go somewhere, and so it must go to TR.
4.
DECREASE. C = Q/V. If voltage stays the same, then as C rises for SU (as D becomes smaller) then C must fall on the other side, and since voltage stays the same, then Q must be the thing that is falling in the equation C = Q/V.
5.
EQUAL TO. I figured You couldn't do the assignment if * something * didn't stay constant, so I assumed it must be the voltage. I'm guess that means that TR and SU are connected in parallel.
6.
LESS THAN. I used C = Q/V and C = ε0*A/d to figure it out. if V1 = V2 then if CTR was smaller than CSU, then QT must be smaller than QS
7.
GREATER THAN. U = . * C * V2 C was larger for SU than TR, and V1 = V2, so USU > UTR
3. The reasoning for this one is based on the equation U = (1/2) * C * V2. As the plate separation for capacitor SU increases, the capacitance for this capacitor decreases, meaning that the energy stored in it also decreases. This energy has to go somewhere, and since the total energy in the system must remain constant, it must transfer to the other capacitor, TR. This results in an increase in the energy stored in TR.
4. Similarly, if the plate separation for capacitor SU decreases, the capacitance for this capacitor increases, meaning that the energy stored in it also increases. This energy has to go somewhere, and since the total energy in the system must remain constant, it must transfer from the other capacitor, TR. This results in a decrease in the energy stored in TR.
5. The charge on plate T, Qt, is equal to the charge on plate S, Qs. This is because they are connected in parallel, meaning that the voltage across them is the same. Since C = Q/V, if the voltage is the same, the charges must also be the same.
6. The energy stored in capacitor SU is greater than the energy stored in capacitor TR. This is because the capacitance for SU is larger than the capacitance for TR, meaning that it can store more energy for the same voltage. This can also be seen in the equation U = (1/2) * C * V2, where the energy is directly proportional to the capacitance.
7. The energy stored in capacitor SU is greater than the energy stored in capacitor TR. This can also be seen in the equation U = (1/2) * C * V2, where the energy is directly proportional to the capacitance. Since the voltage is the same for both capacitors, the one with the larger capacitance (SU) will have a greater energy stored.
5 Most Frequently Asked Questions about Parallel Plates Capacitors, two capacitors
1. What is a parallel plates capacitor?
A parallel plates capacitor is a type of capacitor that consists of two parallel plates separated by a dielectric material. It is used to store and release electrical energy.
2. How do two capacitors connected in parallel behave?
When two capacitors are connected in parallel, the total capacitance is equal to the sum of the individual capacitances. This means that the total charge stored on the two capacitors will be divided between them.
3. What is the formula for calculating the capacitance of two capacitors in parallel?
The formula for calculating the total capacitance of two capacitors in parallel is C = C1 + C2, where C1 and C2 are the individual capacitances of the two capacitors.
4. Can two capacitors with different capacitance values be connected in parallel?
Yes, two capacitors with different capacitance values can be connected in parallel. The total capacitance will be the sum of the individual capacitances, and the charges on the two capacitors will be divided accordingly.
5. What is the purpose of connecting two capacitors in parallel?
Connecting two capacitors in parallel increases the total capacitance, allowing for more charge to be stored. This can be useful in applications where a larger amount of charge is needed, or in circuits where the individual capacitors may not have a high enough capacitance on their own.
