Particle physics basic concept from Standford Uni help
In summary, the conversation discusses how adding up or superposing state vectors corresponding to a particle with momentum k and coefficient e^-ikx results in a position state located at particle x. This is due to the Fourier expansion of a delta function and the relationship between position and momentum in quantum mechanics.
TimeRip496
254
Let's start with a vacuum, I will write |0000...> as |0>.
$$ \psi^+ (x) |0\rangle = \sum_k e^{-ikx} a^+ (k) |0\rangle $$
Qns: What happens if you superpose/add up state vectors corresponding to a particle of momentum k and you add up with coefficient e-ikx?
$$ \sum_k e^{-ikx} a^+ (k) |0\rangle $$ where a+ is a creation operator
Ans: The ans is it is a position state. It is a state with a definite position. What is a position? x. If you add up momentum states with e-ikx, that gives you a position state located at particle x. This is one particle quantum mechanics.
Source: Starts at 40:21
I am lost at this part whereby how multiplying e-ikx with a+(k) gives the position state?
You need to look at the Fourier expansion of a delta function which is the wave function for a particle localized at a point position.
Any position vs momentum picture transformation is going to be a Fourier expansion of the other. Here you simply have it applied to operators in the field theory.
1. What is particle physics?
Particle physics is a branch of physics that studies the smallest building blocks of matter and their interactions. These particles include atoms, protons, neutrons, electrons, and even smaller subatomic particles like quarks and leptons.
2. What are the basic concepts of particle physics?
The basic concepts of particle physics include understanding the fundamental particles and their properties, the forces that govern their interactions, and the mathematical equations that describe their behavior at the subatomic level.
3. How do scientists study particle physics?
Scientists study particle physics through experiments using high-energy particle accelerators, such as the Large Hadron Collider at CERN. They also use theoretical models and mathematical calculations to understand the behavior of particles.
4. What is the Standard Model in particle physics?
The Standard Model is a theoretical framework that describes the fundamental particles and their interactions. It is the most successful and widely accepted theory in particle physics, but it is still incomplete and does not account for certain phenomena, such as gravity.
5. Why is particle physics important?
Particle physics is important because it helps us understand the fundamental nature of the universe and how it functions at the smallest level. It also has practical applications, such as in medical imaging technology and energy production.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
