Can Multiple Periods Determine a Fundamental Period in Functions?
In summary, there is no fundamental period for a constant function, since the set of periods is unbounded below and has no minimum element. However, any real number can be considered a period for a constant function.
Bipolarity
776
Can a function have two periods? If so, which is the fundamental period?
Consider the following function, $$ f : \mathbb{N} → \mathbb{R} $$, defined by
f[n] = 1 if n is a multiple of 2 or 3, and 0 otherwise.
Then it is clear that 2 and 3 are both periods of this function, since translation of the input by either 2 or 3 renders the function's value invariant.
6, being the least common multiple of 2 and 3, is also "a period" of this function. But which is the fundamental period?
Thanks to anyone who can clarify this confusion!
BiP
Mathematics news on Phys.org
Yes, and the smallest positive number is the fundamental.
Well
f(1) = 0
f(2) = 1
f(3) = 1
f(4) = 1
f(5) = 0
f(6) = 1
But ##1 = f(3) \neq f(3+2) = f(5) = 0## so 2 isn't a period.
Well
f(1) = 0
f(2) = 1
f(3) = 1
f(4) = 1
f(5) = 0
f(6) = 1
Ahh, I see, my mistake.
Are there functions for which 2 and 3 are both periods?
BiP
BiP
pwsnafu already answered this question by his example in post #2. f(2) = f(4) = f(6) = 1, and f(3) = f(6) = 1.
(Embarrassed mod note): Disregard what I wrote: 2 is NOT a period of this function.
pwsnafu answered in the negative. This f is not periodic with period 2. Nor is it periodic with period 3.
If any f() is periodic with both period x and with period y then it is clear that it is also periodic with every period that is a non-zero sum of integer multiples of x and y. In particular, it must be periodic with period (y-x).
3-2 = 1. It folllows that in order for f() to be periodic with period 3 and with period 2 that it must then also be periodic with period 1.
jbriggs, yes you are correct. I was lulled into thinking that since f(2) = f(4) = f(6) = 1, that 2 was a period. Not so. Thanks for the correction.
On this subject, you might notice that the constant function ##f(x)\equiv C## has period ##r## for any real number ##r##.
What would be considered the period of a constant function?
BiP
BiP
Pick any number a, let b be an arbitrary real number. Then, since C = f(a) = f(a + b) = C, the period is b. That's pretty much what LCKurtz was saying.
I see, but what would be the fundamental period? 0?
BiP
What is the definition of a fundamental period? If you apply that definition, would a constant function have a fundamental period?
No, because the set of periods is unbounded below?
BiP
You might find this short article in the American Mathematical Monthly interesting:
R. H. Cox and L. C. Kurtz. 1966. Real periodic functions. Am.Math.Mon.,73,761
Here's a link to the article:
http://www.jstor.org/stable/2313992
If you are logged into a university account, you should just be able to open it. It's only about 1 page long in the "classroom notes" section.
Yes. Though I might quibble that the set of [positive] periods is bounded below (by zero). But that lower bound is not member of the set. Accordingly, the set has no minimum element.
What is a periodic function?
A periodic function is a mathematical function that repeats its values at regular intervals. This means that the graph of the function will have a predictable pattern that repeats itself over and over again.
What is the period of a periodic function?
The period of a periodic function is the distance along the x-axis between two consecutive repetitions of the function's values. It is sometimes represented by the symbol T and is usually measured in units of length (such as meters or seconds).
How is the period of a periodic function related to its frequency?
The frequency of a periodic function is the number of cycles (or repetitions) that occur in a given unit of time. It is closely related to the period, as the frequency can be calculated by taking the reciprocal of the period (f = 1/T). This means that the higher the frequency, the shorter the period and vice versa.
What is the difference between a periodic function and a non-periodic function?
A periodic function repeats its values at regular intervals, whereas a non-periodic function does not have a predictable pattern and does not repeat itself. Non-periodic functions may have a finite or infinite number of values, whereas periodic functions have a finite number of values that repeat.
What are some real-world examples of periodic functions?
Periodic functions can be found in many natural phenomena, such as the motion of a swing, the cycles of the moon, or the patterns of a heartbeat. They are also commonly used in fields such as engineering, physics, and economics to model and analyze periodic systems and processes.
  • General Math
