Plasma inside a light bulb?
In summary, the conversation discusses the possibility of having a vacuum inside a light bulb and the use of inert gases to create pressure for incandescent bulbs. It also mentions a DIY project using a car's brake light bulb to create a plasma display.
iScience
466
http://i.imgur.com/bLUjP0Q.jpg
is something like this even possible in a light bulb? i thought the interior was supposed to be a vacuum.
The thin glass used in a typical incandescent light bulb is not near strong enough to sustain a vacuum. Incandescent bulbs are filled with inert gases to about 70% atmospheric pressure.
The lights at the back of a car include a combined rear light / brake light bulb.
Usually this is replaced when one of the lamp filaments burns out.
This gives you a chance to experiment since you now have a working filament and a disconnected wire which will work as an anode if the filament is supplied with its normal voltage. It will work as a diode if the bulb is under vacuum or as a plasma display if it contains gas.
Local repair shops usually discard such bulbs but would probably save you a few if you ask.
Yes, it is possible for plasma to exist inside a light bulb. In fact, plasma is what allows the light bulb to produce light. When electricity is passed through the filament inside the bulb, it heats up and emits energy in the form of light. This process ionizes the gas inside the bulb, creating a plasma state. The plasma then emits the light that we see. The interior of a light bulb is not a complete vacuum, but rather filled with a gas mixture that allows for the formation of plasma.
1. What is plasma inside a light bulb?
Plasma is a state of matter that is created when a gas is heated to extremely high temperatures. In a light bulb, the gas inside is heated by an electric current, creating a plasma state.
2. How does plasma help a light bulb produce light?
When an electric current passes through the plasma, it excites the gas molecules and causes them to release energy in the form of light. This process is known as electroluminescence.
3. Why is plasma used instead of a regular gas in light bulbs?
Plasma can produce more light and can operate at higher temperatures compared to a regular gas, making it more efficient for producing light in a light bulb.
4. Is plasma inside a light bulb dangerous?
No, the amounts of plasma inside a light bulb are very small and pose no danger to humans. However, caution should always be taken when handling a light bulb as it can still cause burns if touched while in use.
5. Can plasma inside a light bulb be recycled?
Yes, most light bulbs are recyclable, including those with plasma inside. However, it is important to dispose of them properly to avoid any potential harm to the environment.
  • Electrical Engineering
