Why Do Blood Pressure Levels Vary Throughout the Cardiovascular System?
In summary, blood pressure is the force that blood exerts on the blood vessel walls. It is highest in the left ventricle of the heart and decreases as it travels through the vasculature due to the branching of arteries, compliance of vessels, and the rate of blood flow. Blood pressure is relative to atmospheric pressure and is typically measured in millimeters of mercury. It is regulated by both central and local control, and can be affected by various factors such as heart rate, stroke volume, and vascular resistance.
jaechung
Hi, I am studying about blood pressure. And I have some questions.
The blood pressure in the left ventricle is about 105mmHg, and that in the right atrium is about 0 to 2 mmHg,
Why do pressures decrease through our vasculature?
And what kind of pressures are the pressures in the blood? Is it just "relative pressure?" In the blood, what is the total, atmospheric, and gauge pressure?
Please help me understand this concept easily and clearly.
Thanks in advance.
Biology news on Phys.org
The left ventricle of the heart provides a pulsitile pressure to force the flow through most of arteries. It therefore has a high and low pressure for each heart beat cycle.
The pressure pulse pushes blood through the vessels, raising the blood pressure at those peripheral locations.
Liquid flow is similar to electrical flow: Flow = Pressure/Resistance :: Current = Voltage/Resistance
Smaller vessels have more resistance.
As the blood flows out, the arteries branch to smaller arteries. This spreads out the volume of flowing blood which decreases its local effects on pressure.
In addition, there is compliance in arteries (more so in veins). This means the vessels can expand to take in more blood volume while having a smaller than expected pressure increase. On the other hand, the vessels will contract back toward their normal size providing some additional pressure later in the heart beat cycle that would be expected from just the heart beat. This effects the local blood pressure by reducing the highs, increasing the lows, and widening the the overall pressure pulse.
Another way you could think about this is in the rate of flow. All the blood coming out of the heart goes through the aorta (first vessel after the heart). As the vessels split up so the blood can go through out the body the cross-sectional area of all the arteries increases (compared to the aorta) and so the flow rate (of the single heart beat goes down).
I think blood pressure is relative to atmospheric pressure. In the doctor's office blood pressure is measured by detecting the heart beat downstream of a constriction made by an air filled cuff. The pressure in the blood vessels have to exceed the pressure in the cuff for the beat to be detected on the other side of it. Different (high or low level components) can be detected at different pressures as the cuff pressure is reduced.
After going through the capillaries, there is very little blood pressure to drive blood flow back to the heart. Muscle contractions add local pressure on veins by squeezing the blood along, combined with valves that only permit the blood to flow in only one direction.
Likes Fra, Spinnor and berkeman
That does appear to be correct. Especially since atmospheric pressure is 760mm of Hg, it would be weird if the BPs we measure on patients were absolute. We'd get squished... :smile:
Here is a related paragraph from Wikipedia:
https://en.wikipedia.org/wiki/Millimeter_of_mercury
Use in medicine and physiology
In medicine, pressure is still generally measured in millimeters of mercury. These measurements are in general given relative to the current atmospheric pressure: for example, a blood pressure of 120 mmHg, when the current atmospheric pressure is 760 mmHg, means 880 mmHg relative to perfect vacuum.
Likes Fra, jim mcnamara and BillTre
The question is answerrd already but to add a detail to the flow = pressure / resistance note.
The typical relation from the point of view of the heart is
MAP - CVP = SVR × CO
CO = cardiac output in liter/min
SVR = Systemic (total) Vascular Resistance
MAP - CVP = the pressure DIFFERENCE between arterial output and venous return. This is the "pump pressure"
Further CO = HeartRate x StrokeVolume
The regulation of flow are both under central and local control and modulates both the heart and the vascular resistance in interplay.
So while we have a simple "ohms law analogy" the full regulatory implementation here is extremely complex as if you change one one parameter the remainig regulatory system may partially adapt or compensate!
/Fredrik
Likes BillTre
1. What is blood pressure?
Blood pressure is the amount of force that your blood puts on the walls of your arteries as it flows through your body. It is measured in millimeters of mercury (mmHg) and is recorded as two numbers: systolic pressure (the top number) and diastolic pressure (the bottom number).
2. Why is it important to understand blood pressure?
High blood pressure (hypertension) is a risk factor for many serious health conditions such as heart disease, stroke, and kidney disease. Understanding your blood pressure and taking steps to keep it within a healthy range can help prevent these health issues.
3. What is considered a normal blood pressure reading?
A normal blood pressure reading is less than 120/80 mmHg. A reading of 120-129/80 mmHg is considered elevated, 130-139/80-89 mmHg is considered stage 1 hypertension, and 140/90 mmHg or higher is considered stage 2 hypertension.
4. How can I lower my blood pressure?
There are many ways to lower your blood pressure, including maintaining a healthy weight, exercising regularly, reducing sodium intake, following a balanced diet, limiting alcohol consumption, managing stress, and taking any prescribed medications as directed by your doctor.
5. What are the symptoms of high blood pressure?
High blood pressure is often called the "silent killer" because it typically has no noticeable symptoms. That's why it is important to have your blood pressure checked regularly by a healthcare professional. In rare cases, very high blood pressure may cause symptoms such as headaches, dizziness, chest pain, or shortness of breath.
  • Biology and Medical
  • Materials and Chemical Engineering
13K
323K
  • DIY Projects
