jperk980
- 47
Could anyone give me help on these problems thank you.
1. An object falls from height h from rest and travels 0.46h in the last 1.00 s. Find the height and time of its fall. Explain the physically unacceptable solution of the quadratic equation in t that you obtain.
I think this problem uses the equation y=vi*t-.5gt^2, but I am not sure how to use it. Also i have no idea how to even start thinking about answering the last question.
2.A drowsy cat spots a flowerpot that sails first up and then down past an open window. The pot was in view for a total of 0.37 s, and the top-to-bottom height of the window is 1.65 m. How high above the window top did the flowerpot go?
I know this equation uses the formula y=vi*t-.5gt^2 but I am not sure how to input the information into the formula.
A lead ball is dropped into a lake from a diving board 5.12 m above the water. It hits the water with a certain velocity and then sinks to the bottom with this same constant velocity. It reaches the bottom 4.72 s after it is dropped. (Assume the positive direction is upward.)How deep is the lake?What is the average velocity of the ball? Suppose that all the water is drained from the lake. The ball is now thrown from the diving board so that it again reaches the bottom in 4.72 s. What is the initial velocity of the ball?
I do not know were to start on this question.
Thanks for all of your help
