How Do Protons Hit a Target Under Electric Field Influence?
In summary, the protons are projected with an initial speed of 9550 m/s into a region with a uniform electric field of 720 N/C [down]. To hit a target 1.27mm away, two projection angles of 37 and 53 degrees are needed. The total duration of flight for each trajectory is 0.22 microseconds.
an_mui
47
Protons are projected with an initial speed of v0 = 9550 m/s into a region in which a uniform electric field E = 720N/C [down] is present. The protons are to hit a target that lies a horizontal distance of 1.27mm from the point at which the protons are launched.
a) find the two projection angles theta that will result in a hit
b) what is the total duration of flight for each of the two trajectories?
a) equations for projectile motion
(1) x = v0 cos (theta) t
(2) y = v0 sin (theta) t - 1/2gt^2
gelec = |field| / mass = |qfield x E| / m
x = (R, 0) where R = 1.27mm = 1.27 x 10^-3 m
solve equation 2 for t. t = 0 or t = 2v0sin theta / g (we use this one)
(3) R = 2Vo^2 sin (theta) cos (theta) / gelec
(4) sin (theta) cos (theta) = A = a number
square equation (4) : sin (theta)^2 cos (theta)^2 = A^2
sin (theta)^2 (1 - sin (theta)^2) = A^2
sin (theta)^4 - sin (theta)^2 + A^2 = 0
using quadratic equation ... Let x be sin (theta)^2
x^2 - x + A^2 = 0
1 +/- (1 - 4A^2)^1/2 <--- equation 5
a) theta = inverse sin (sqrt x)
= 53 or 37 degrees.
I'd really appreciate it if someone could check my work / answer over for me. Thanks in advance.
b) t = (2vosintheta) / g
= 2.2 x 10^-7 s
Check your calculations. I am getting ~ 5 and 85 degrees.
After this, you can simplyfy your calculation a lot by using the fact that,
2sin(theta)cos(theta)= sin(2theta)
So you have sin(2theta)= 2*A = a number and solve for theta.
You will get the second value for theta by knowing that sin(pi - theta)= sin (theta).
Hope this helps.
hm . i still got 37 and 53 degrees using your method, i guess i might've calculated my A value wrong then.
this is what i got.
R = 2 Vo^2 sin (theta) cos (theta) / gelec
R = 1.27 x 10^-3
gelec = |Felec| / mass = |qfield x E| / m
= (1.6 x 10^-19)(720) / 1.67 x 10^-27
= 6.898 x 10^10
Vo = 9550
sin (theta) cos (theta) = (R x g elec) / 2Vo^2
= 0.48
= A
I used the electron mass. Sorry. You are right. I get ~37 and 53 deg.s now and t = 0.22 micro secs.
Related to How Do Protons Hit a Target Under Electric Field Influence?
1. What is projectile motion?
Projectile motion is the motion of an object through the air or through space under the influence of only gravity and air resistance.
2. How does projectile motion apply to protons?
Protons are positively charged particles found in atoms. When they are accelerated in an electric field, they experience a force due to their charge and can be considered as projectiles.
3. What factors affect the projectile motion of protons?
The factors that affect the projectile motion of protons include their initial velocity, angle of launch, air resistance, and the strength of the electric field that is accelerating them.
4. What is the significance of studying the projectile motion of protons?
Studying the projectile motion of protons can help us understand the behavior of charged particles in electric and magnetic fields. It also has practical applications in fields such as particle physics, medical imaging, and nuclear energy.
5. How is the trajectory of a proton in projectile motion calculated?
The trajectory of a proton in projectile motion can be calculated using the equations of motion, taking into account the initial velocity, angle of launch, and the effects of gravity and air resistance. Advanced calculations may also involve the use of vector components and electric field equations.
