Quantitative study of mirage
In summary: Once you have that, you can solve for the other two.In summary, at a distance greater than h from the mirage, the ray of light will still be able to see it. However, the minimum possible distance between you and the mirage is d=H.
Quantum Sphinx
Question:[/B] Imagine you are in a massive desert. There is a tower of height H. A light source at the top of the tower can emit light in all directions. You are a person whose eyes are at a height h (h<H) above the ground. The refractive index of the air varies as μ=kd where k is a positive constant and d is the distance above the ground.
  1. What is the minimum distance at which you will still be able to see the mirage.
  2. What is the minimum possible distance between you and the mirage.
  3. If the ray starts off making an angle α below the horizontal what is the condition that a mirage is created
(The 3 questions are independent)
2. Homework Equations :
snell's law
2. The attempt at a solution
My approach:
I started off by assuming an element of height dx at an elevation x above the ground. Then I assumed that the ray of light is incident at an angle of θ and that the angle of refraction isθ+dθ. the refractive index changes from μ(x+dx) to μ(x). So,
μ(x+dx)⋅sin⁡(θ)=μ(x)⋅sin⁡(θ+dθ)
Solving this gave me weird results. I think it was because I was unable to incorporate Total Internal Reflection into it.
If somebody could either point me in the right direction for solving the question or point out an error (if there is one) in the question (because I made the question myself) then I would be grateful.
Please post your working. It will be important to get the sign right in your first equation.
Edit: I get that the trajectory of the ray is an arc cosh function.
That is the first equation.
Then -
μ⋅x⋅sin(θ) + μ⋅sin(θ)⋅dx = μ(x)⋅sin(θ)⋅cos(dθ) + μ(x)⋅cos(θ)⋅sin(dθ)
( assumptions - cos(dθ) = 1 and sin(dθ) = dθ )
which gives -
sin(θ)⋅dx = x⋅cos(θ)⋅dθ
dx/x = cot(θ)⋅dθ
Integrating,
[ln x] = [ ln |sin(θ)| ]
The problem comes in putting the limits. What limit should I use over [ ln |sin(θ)| ]. For question 1, the limits over [ln x] should be from H to h(I think).
Very sorry - I was busy when I saw your reply and forgot to come back to it.
For a mirage to occur, what value of angle must be reached before what value of height?
Edit: just realized something about the problem statement. It implies the refractive index is zero at d=0. It cannot be less than 1, surely.
For the first two parts of the question, you need to look at how horizontal distance gets into the equation (x is your vertical distance).
1. What is a mirage?
A mirage is a naturally occurring optical illusion where an object appears to be in a different location than it actually is due to the bending of light through different air temperatures.
2. How is a mirage formed?
A mirage is formed when there is a significant temperature gradient in the air near the ground, causing light to refract and create an inverted image of the object.
3. What is the goal of a quantitative study of mirages?
The goal of a quantitative study of mirages is to collect and analyze numerical data in order to better understand the factors that contribute to the formation and characteristics of mirages.
4. What methods are used in a quantitative study of mirages?
Quantitative studies of mirages often involve using instruments such as thermometers, humidity sensors, and spectrophotometers to measure environmental conditions and collect data. Mathematical models and statistical analysis may also be used to interpret the data.
5. What are some potential applications of a quantitative study of mirages?
The findings of a quantitative study of mirages can be used in various fields such as meteorology, optics, and transportation to improve weather forecasting, understand light refraction, and mitigate potential hazards on roads and runways caused by mirages.
