What is a Quasi Upper Triangular Matrix?
  • Thread starter jezza10181
  • Tags
    Matrix
In summary, a 'quasi upper triangular matrix' is a block upper triangular matrix with either 1x1 or 2x2 blocks on the diagonal. It is mentioned in the book 'Matrix Computations' by Golub & Van Loan, and although there is no formal definition available, it can be understood from the context in the book. There are also online resources, such as the first link provided, that provide further explanation and examples of this type of matrix.
jezza10181
Hi, I am dealing with a 'quasi upper triangular matrix', that is mentioned in the book 'Matrix Computations' by Golub & Van Loan. However, neither in the book itself, or anywhere on the internet, am I able to find a formal definition of a 'quasi upper triangular matrix'.
I have a rough idea what this is.. an upper triangular matrix, with the odd non-zero element(s), somewhere along it's sub-diagonal. But I need an actual formal definition. Anyone furnish me with one please?
You probably mean "a block upper triangular matrix with either 1x1 or 2x2 blocks on the diagonal."
http://books.google.co.uk/books?id=...epage&q=quasi upper triangular matrix&f=false
http://reference.wolfram.com/legacy.../AdvancedDocumentationLinearAlgebra3.4.5.html
It should be clear exactly what G&VL mean from the context in the book.
Thanks, the first link was very helpful
A Quasi Upper Triangular Matrix is a type of matrix where all the elements below the main diagonal are zero, and the elements on and above the main diagonal are either non-zero or zero. This matrix is also known as a subdiagonal matrix.
What are the properties of a Quasi Upper Triangular Matrix?
A Quasi Upper Triangular Matrix has the following properties:
  • It is a square matrix.
  • All elements below the main diagonal are zero.
  • The elements on and above the main diagonal can be either non-zero or zero.
  • The main diagonal can have both zero and non-zero elements.
  • The eigenvalues of a Quasi Upper Triangular Matrix are the elements on the main diagonal.
What is the difference between a Quasi Upper Triangular Matrix and an Upper Triangular Matrix?
The main difference between a Quasi Upper Triangular Matrix and an Upper Triangular Matrix is that in a Quasi Upper Triangular Matrix, the main diagonal can have both zero and non-zero elements, while in an Upper Triangular Matrix, all elements on the main diagonal are non-zero.
What are some applications of Quasi Upper Triangular Matrices?
Quasi Upper Triangular Matrices have various applications in mathematics, physics, and engineering. Some common applications include solving linear systems of equations, computing eigenvalues and eigenvectors, and representing networks and systems in control theory.
How is a Quasi Upper Triangular Matrix created?
A Quasi Upper Triangular Matrix can be created by selecting a square matrix and setting all the elements below the main diagonal to zero. The elements on and above the main diagonal can be chosen freely to create the desired matrix. Alternatively, a Quasi Upper Triangular Matrix can be obtained by applying row and column operations to a given matrix.
  • Linear and Abstract Algebra
9K
30K
13K
