Question about gravitational force
In summary, according to PeroK, the gravitational force is going in the opposite direction of the action (down in this case), depending on which point you choose to stand on.
Ellio
none
g= 9.81 / or -9.81 m/s²
Hello, I hope you are all very well !
Let's say a man, standing on point "0 m" throws a ball 10 m in the air. The gravitational force goes in the opposite (down (always)) of the action (up): I supposed it's -9.81 m/s².
The same action but this time the man stands on the point "10 m" and the stone goes up to 0 m. The gravitational force is still going on the opposite of the stone but this time is going in the same direction (down) as the direction of the action (down): here it would be 9.81 ?
By definition:
##g = 9.81 m/s^2##
When you set a problem up, you get to choose whether up or down is taken to be the positive direction. Then ##a = \pm g##, as appropriate.
Likes collinsmark
To elaborate on what PeroK said, you are free to choose whether up is positive or down is positive. However, it isn’t just the sign of the gravitational acceleration you are choosing. It is the direction of the coordinate system. For example, if you choose up as positive, then gravitational acceleration which points down will be negative, but also position is more positive as you go up and positive velocity refers to traveling upward.
So, you are welcome to choose up or down as positive, but you must keep the same convention for the whole problem.
Ok thank you very much for your answers !
Likes berkeman
1. What is gravitational force?
Gravitational force is a natural phenomenon by which objects with mass attract one another. It is often described as the force that pulls objects towards the center of the Earth.
2. What causes gravitational force?
Gravitational force is caused by the presence of mass. The more massive an object is, the stronger its gravitational force.
3. How is gravitational force calculated?
The force of gravity between two objects can be calculated using the formula F = G * (m1 * m2) / r^2, where G is the gravitational constant, m1 and m2 are the masses of the two objects, and r is the distance between them.
4. Does gravitational force affect all objects equally?
Yes, gravitational force affects all objects equally regardless of their mass. However, objects with larger masses will experience a greater force of gravity.
5. Can gravitational force be shielded or cancelled out?
No, gravitational force cannot be shielded or cancelled out. It is a fundamental force of nature and is always present between objects with mass.
