Question about linear programming
The discussion centers on three linear equations, y1, y2, and y3, that intersect at a common point. The area between the curves y1 and y2 from 0 to the intersection is identified as the "feasible region," particularly in economic applications. While the feasible region is acknowledged, the conversation shifts to the utility of calculating its actual size. Determining the size of this region can provide insights into resource allocation and optimization in economic models. Understanding the area can enhance decision-making processes within the context of the specific application.
homomorphism
basically, let's say i have three linear equations, y1, y2, and y3.
assume y1 = ax+b where a and b are constants
assume y2 = mx+k where m and k are constants
assume y3 = n where n is a constant
also, now assume that they all intersect at y1=y1=y3=n.
would the area between the curves, y1 and y2, from 0 to the intersection represent anything? I've attached a sample pic for reference.
Mathematics news on Phys.org
Wow, I think I repeating what I just said in the previous thread! What anything in mathematics "represents" depends upon the specific application. In economics that area is commonly referred to as the "feasible region" because it is, by the terms of the application that gives you those equations, the area in which a solution must occur.
well...i know it's the feasible region. But let's stick with the economics example...does computing the actual size of that region give anything useful?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
