Quick sequence proof help
In summary, if the sequence ##x_n## is bounded by ##B## and ##y_n \rightarrow + \infty##, then by choosing ##n > N## for some ##N \in \mathbb{R}##, we can ensure that ##x_n + y_n > M + B## for any ##M > 0##, thus proving that ##x_n + y_n \rightarrow + \infty##.
phospho
251
show if the sequence ## x_n## is bounded and ## y_n \rightarrow + \infty ## then ## x_n + y_n \rightarrow + \infty ##
my attempt
if ## x_n ## is bounded then ## P \leq x_n \leq Q ## for some ## P,Q \in \mathbb{R} ## if ## y_n \rightarrow + \infty ## then ## \forall M>0 ## ## \exists N \in \mathbb{R} ## s.t. ## \forall n > N \Rightarrow y_n > M ##
now we need to prove that ## \forall M' > 0 ## ## \exists N_1 \in \mathbb{R}R ## s.t. ## \forall n >N_1 \Rightarrow z_n > M' ## where ## z_n = x_n + y_n ##
## y_n > M ## therefore ## x_n + y_n > M + P ## hence take ## M' = M + P ## and we get ## z_n = x_n + y_n > M' ## hence ## \forall n > N_1 ## ## z_n > M' ##
is this all or would I need to add something
I'm also worried about if P is negative, could I just state that ## M > P ## ?
my attempt
## y_n > M ## therefore ## x_n + y_n > M + P ## hence take ## M' = M + P ## and we get ## z_n = x_n + y_n > M' ## hence ## \forall n > N_1 ## ## z_n > M' ##.
And, for that matter, both ##P## and ##Q## might be negative. To get around having to deal with those cases, just use that ##\{x_n\}## is bounded means there is ##B\in \mathbb R## such that ##|x_n|<B## for all ##n##. That tells you ##-B<x_n<B##. Can you get a lower bound for ##x_n+y_n## from that? Then figure out if you can make that greater than M'.
the lower bound would be ## x_n + y_n > M - B ## no? Also, could I not just state that we choose ## M > -B ## seeing as M can be any large number?
Also, I don't quite understand how you got ## -B < x_n < B ## if it's bounded surely the upper and lower bounds are not necessarily the same?
There is no M in my reply or question.
They don't have to be the same to make the claim there is a ##B## that ##|x_n|<B##.
Is xn is between -B and B then surely B=B? The lower bound would be xn + yn > yn - B
Not sure what you are getting at there, but yes, B=B.
Yes. Now you are trying to choose ##n## large enough so that given any ##M##, ##x_n+y_n > M##. And you know you can make ##y_n## large. How large does ##y_n## have to be?
yn has to be larger than B?
Stop guessing and start thinking. You have ##x_n+y_n>y_n-B## and you want ##x_n+y_n## to be greater than ##M##. How big does ##y_n## need to be to make that happen?
there's an alternate way if you go about it by contradiction
lckurtz said:
stop guessing and start thinking. You have ##x_n+y_n>y_n-b## and you want ##x_n+y_n## to be greater than ##m##. How big does ##y_n## need to be to make that happen?
## y_n > M + B ##?
phospho said:
## y_n > M + B ##?
Show me why you say that and what it does for you. Write down the inequalities you have. You are almost done.
we have ## |x_n| \leq B ## and ## x_n + y_n \geq y_n - B ##
## \forall M > 0 \exists N \in \mathbb{R} ## s.t. ## n > N \Rightarrow y_n > M + B ## so ## x_n + y_n > M + B - B=M ##
this tell us for ## M > 0 ## ## \exists N \in \mathbb{R} ## s.t.## n>N \Rightarrow z_n > M ## where ## z_n = x_n + y_n ## (i.e. z_n -> +infinity)
OK, that looks pretty good. Well done.
Likes 1 person
Thank you for help
My lecturer keeps telling us that presentation and our grammar is very important when constructing proofs so could you please read through the entire proof below? (this is for an introductory to analysis class):
As ## x_n ## is bounded ## \exists B \in \mathbb{R}## s.t. ##|x_n| \leq B ##
Suppose ## \forall M_1 > 0 ## since ## y_n \rightarrow \infty ## as ## n \rightarrow \infty ## ## \exists N \in \mathbb{R} ## s.t. ## n > N\Rightarrow y_n > M_1 ## where ##M_1 = M_2 + B ##
as ## |x_n| \leq B ## ## -B \leq x_n \leq B ## so for ## n > N ## ## x_n + y_n \geq B + y_n > M_1 + B > M_2 + B - B = M_2 ## hence ## \forall M_2 > 0 ## ## \exists N \in \mathbb{R} ## s.t. ## n>N \Rightarrow x_n + y_n > M_2 ## which is the definition for divergence to ## +\infty ## therefore ## x_n + y_n \rightarrow +\infty ##
phospho said:
Thank you for help
Yes, I agree with your teacher. The order you write it up isn't necessarily the order in which you analyze the problem.
As ## x_n ## is bounded ## \exists B \in \mathbb{R}## s.t. for all n ##|x_n| \leq B ##
Here you should put in the steps leading to ##-B+y_n \le x_n+y_n##
As ## y_n \rightarrow \infty ## as ## n \rightarrow \infty ## then ## \forall M > 0 ## ## \exists N \in \mathbb{R} ## s.t. ## n > N \Rightarrow y_n > M + B ##
Instead of writing that line like that say it more like this: Suppose ##M>0##. Since ##y_n\rightarrow \infty## there exists ##N \in \mathbb{R} ## such that for all ##n>N##, ##y_n>M+B##.
consider ## x_n \geq -B ## so ## x_n + y_n > M + B - B = M ## hence ## \forall M > 0 ## ## \exists N \in \mathbb{R} ## s.t. ## n>N \Rightarrow x_n + y_n > M ## which is the definition for divergence to ## +\infty ## therefore ## x_n + y_n \rightarrow +\infty ##
Now instead of that last two lines you can just say since ##n > N##, ##x_n+y_n \ge ...## and put your string of inequalities ending with ##>M##.
I have edited my previous post if you could take a look at it. Thanks.
No, I'm sorry, I don't feel like starting over. You shouldn't make major edits after the post has been replied to. It makes it very hard to follow the thread. Now you have ##M_1## and ##M_2##'s floating around and silly things like ##|x_n|\le B-B##. It's OK if you don't want to follow my suggestions, but at this point I will let your teacher analyze it. You were so close...
OK I'll be sure not to make edits but instead post again, but I figured it's still easy to follow as you quoted me so readers can see what you were asking me to change specifically, and I have changed it. Also, I do not have ## |x_n| \leq B-B ## it looks like that because I don't know how to use tex and put "## |x_n| \leq B ## ## -B \leq x_n \leq B ##" if you quote me you will see the code and that it's separated.
I also think it's really demotivating to a student like myself if you say stuff like "you were so close", it just implies I can almost do it, but I'm not there and that you (assuming you are a teacher), have given up on me because I edited my post instead of replying.
Anyhow, I appreciate the help and I'm happy with my solution and I hope the PHD student who will be marking my work will be also.
Thanks again.
Well that helps some.
Thanks again.
I'm sorry you feel demotivated. I have spent a lot of time in this thread. When you were finally ready to write it up I gave you clear suggestions how to do it properly. All you needed (and still do need) to do was follow the suggestions. There was something to be learned there.
I frequently don't enter this kind of thread because of the difficulty of getting ideas across online. What could be done in a few minutes in person can take days online, especially when we require the student to do most of the work, giving only general hints and guidelines. Anyway, my real life requires me to leave for the day. I'm sure your teacher will have some suggestions.
I especially agree with the bolded part, it's very hard for me to smooth something over online, but sometimes I have no other options but to try.
I really appreciate your help as you've helped me with other questions also. I have reached a proof with which I am happy with (after taking your suggestions). Thanks again.
1. What is a quick sequence proof?
A quick sequence proof is a mathematical method used to prove the validity of a statement or theorem by showing that it holds true for a finite sequence of numbers or objects. It is a useful tool for simplifying complex proofs and providing a clear and concise argument.
2. When is a quick sequence proof most commonly used?
A quick sequence proof is most commonly used when dealing with problems that involve numerical or sequential patterns. It is also used in many areas of mathematics, including algebra, number theory, and calculus.
3. What are the steps involved in a quick sequence proof?
The steps involved in a quick sequence proof are as follows:
  1. State the statement or theorem to be proved.
  2. Construct a finite sequence of numbers or objects that follows a clear pattern or rule.
  3. Show that the statement holds true for the first few terms of the sequence.
  4. Assume the statement holds for some arbitrary term in the sequence.
  5. Use this assumption to prove that the statement also holds for the next term in the sequence.
  6. Repeat this process until the statement is proven to hold true for all terms in the sequence.
  7. Conclude that the statement is true for all cases, as it holds true for an infinite number of terms in the sequence.
4. What are the benefits of using a quick sequence proof?
There are several benefits of using a quick sequence proof, including:
  • It simplifies complex proofs by breaking them down into smaller, more manageable steps.
  • It provides a clear and concise argument for the validity of a statement or theorem.
  • It can help to identify patterns and relationships between numbers or objects.
  • It can be used to prove statements that are difficult to prove using other methods.
5. Are there any limitations to using a quick sequence proof?
While a quick sequence proof can be a useful tool in many cases, it may not be applicable in all situations. Some limitations of using a quick sequence proof include:
  • It can only be used to prove statements that follow a clear and predictable pattern.
  • It may not be the most efficient method for proving certain statements.
  • It may not provide a complete understanding of why a statement is true, as it only focuses on a finite sequence of terms.
