Rolling 20 times a fair dice
In summary: Thinking) Do we then need to find the inverse of this probability to get the value of $k$? (Wondering)Yes, a table like that or using some tool that can calculate the inverse cumulative binomial function.Yes, that is correct. So we can set it up as:$$\sum_{i=0}^{k-1}\binom{20}{i}\cdot \left (\frac{1}{6}\right )^i\cdot \left (\frac{5}{6}\right )^{20-i}=89.82\%$$And then find the inverse or use the table/tool to find the value of $k$. (Nod)
mathmari
MHB
5,049
Hey! :eek:
Tim rolls $20$ times a fair dice.
  • Calculate the probability to get a "$3$" exactly $8$ times.
  • The probability to get at least $k$ times a "$5$" is equal to $10,18\%$ Calculate $k$.
  • Explain the relation to the term $\displaystyle{\sum_{i=0}^2B\left (10;\frac{5}{6};i\right )}$.
I have done the following:
  • The probability to get a "$3$" is equal to $\frac{1}{6}$. If we throw $20$ times the dice the probability to get exactly eight "$3$" is equal to $\binom{20}{8}\cdot \left (\frac{1}{6}\right )^8\cdot \left (1-\frac{1}{6}\right )^{20-8}=\binom{20}{8}\cdot \left (\frac{1}{6}\right )^8\cdot \left (\frac{5}{6}\right )^{12}\approx 0.84\%$.
    Is this correct?(Wondering)
  • We have that \begin{align*}P(X\geq k)=10,18\% &\Rightarrow 1-P(X\leq k)=10,18\% \\ & \Rightarrow \sum_{i=0}^k\binom{20}{i}\cdot \left (\frac{1}{6}\right )^i\cdot \left (1-\frac{1}{6}\right )^{20-i}=89.82\% \\ & \Rightarrow \sum_{i=0}^k\binom{20}{i}\cdot \left (\frac{1}{6}\right )^i\cdot \left (\frac{5}{6}\right )^{20-i}=89.82\% \end{align*} How can we continue to get the value of $k$ ? (Wondering)
  • Is this the formula we used in the previous question, just with other numbers? (Wondering)
mathmari said:
Hey! :eek:
    Is this correct?
Hey mathmari!
Yep. (Nod)
Shouldn't it be $P(X\geq k)=10.18\% \Rightarrow 1-P(X{\color{red}<} k)=10.18\%$ ? (Worried)
Can't we calculate those terms until we get to the percentage? (Wondering)
Alternatively we can use some tool or table to calculate the inverse cumulative binomial function. (Nerd)
Close, but not exactly.
You effectively wrote that that "at least $k$ times a $5$" is the same as $1$ minus "less than $k$ times a $5$".
Or:
$$P(\text{at least k times 5}) = 1- P(\text{less than k times a 5})$$
The value $B\left (10;\frac{5}{6};i\right )$ is the probability that $i$ times out of $10$ we do not roll a $5$.
In our case "at least $k$ times a $5$" is the same as "less than $10-k$ times not a $5$".
In formula form:
$$P(\text{at least k times 5}) = P(\text{less than 10-k times not a 5})$$
(Thinking)
So we have the following:
\begin{align*}P(X\geq k)=10,18\% &\Rightarrow 1-P(X< k)=10,18\% \\ & \Rightarrow P(X<k)=89,82\% \\ & \Rightarrow P(X\leq k-1)=89,82\% \\ & \Rightarrow \sum_{i=0}^{k-1}\binom{20}{i}\cdot \left (\frac{1}{6}\right )^i\cdot \left (1-\frac{1}{6}\right )^{20-i}=89.82\% \\ & \Rightarrow \sum_{i=0}^{k-1}\binom{20}{i}\cdot \left (\frac{1}{6}\right )^i\cdot \left (\frac{5}{6}\right )^{20-i}=89.82\% \end{align*} or not? (Wondering)
Could you explain to me further how we could calculate $k$ from here? I got stuck right now. (Wondering)
Or:
In formula form:
(Thinking)
So, do we have that $\displaystyle{\sum_{i=0}^2B\left (10;\frac{5}{6};i\right )}$ is the probability that neither $0$ nor $1$ time out of $10$ we do not roll a $5$, i.e. at least twice out of $10$ we don't roll a $5$, i.e. at most $8$ times out of $10$ we roll a $5$ ? (Wondering)
Yes.
We can write:
=\overbrace{\left (\frac{5}{6}\right )^{20}
+ \binom{20}{1}\cdot \left (\frac{1}{6}\right )^1\cdot \left (\frac{5}{6}\right )^{19}
+\ldots}^{k\text{ terms}}
\approx\overbrace{0.26\% + \ldots}^{k\text{ terms}}
=89.82\%$$
We can approximate each term... it is quite a few though... (Sweating)
Perhaps we should take the other approach. (Thinking)
You are off by $1$ in each case. (Worried)
The sum is up to and including $i=2$, isn't it?
Yes.
We can write:
=89.82\%$$
Do you mean such a table ? (Wondering)
Ah yes, so is it as follows?
$\displaystyle{\sum_{i=0}^2B\left (10;\frac{5}{6};i\right )}$ is the probability that neither $0$ nor $1$ nor $2$ time out of $10$ we do not roll a $5$, i.e. at least three times out of $10$ we don't roll a $5$, i.e. at most $7$ times out of $10$ we roll a $5$
(Wondering)
Such a table yes, except that that one is for the t-distribution instead of the binomial distribution.
How about this table?
Shouldn't it be:
$\displaystyle{\sum_{i=0}^2B\left (10;\frac{5}{6};i\right )}$ is the probability that neither $0$ nor $1$ nor $2$ times out of $10$ we do not roll a $5$, ... (Wondering)
1. What is the probability of rolling a specific number (e.g. 5) exactly 20 times in a row?
The probability of rolling a specific number 20 times in a row with a fair dice is 1 in 3,486,784,401,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,000,
