How Does a Rolling Sphere Overcome a Block Without Slipping?
In summary, a uniform solid sphere of radius R and mass M rolls without slipping on a horizontal plane and collides with a fixed block of height h < R. The initial kinetic energy and angular momentum of the sphere can be calculated, and the minimum speed required for the sphere to climb over the block can be determined. However, some mechanical energy is dissipated in the process due to friction, resulting in energy not being conserved.
Mr.Darcy
A uniform solid sphere of radius R and massM rolls without slipping on
a horizontal plane. The centre of mass of the sphere moves initially with
velocity ~v directed perpendicularly to a fixed block of height h < R.
The sphere hits the block and the collision is such that the point P on
the sphere which touches the block does not slip and remains in contact
with the block until the sphere starts rolling on top of the block. See
figure belowa) Compute the initial kinetic energy of the sphere and its angular
momentum with respect to the point P.
[Notice: The angular momentum is a vector, so it is characterised
by its length and direction.]
b) Determine the minimum value, vmin, of the initial speed of the
centre of mass of the sphere, which allows it to climb over the block
(express the result in terms of the parameters of the problem and
the gravitational acceleration g).
c) Assuming that the initial velocity of the centre of mass is greater
than the vmin found in (b), compute the amount of mechanical
energy dissipated in the process.
Why is energy not conserved?
Hi guys.
So I got the first bit. I think K is just equal to sum of translational and rotational energies- that is K=1/2Mv^2+2/5MR^2. and then using the P-A theorem find the angular momentum to be 7/5MVR.
I'm not so sure how to go about the second part though. I got v=gsqrth^2-2hr but don't think this is right.
any help appreciated!
a) The initial kinetic energy of the sphere is K = 1/2Mv^2 + 2/5MR^2 and its angular momentum is L = 7/5MVR.b) The minimum speed, vmin, of the centre of mass of the sphere required for it to climb over the block is given by vmin = √gh(h - 2R).c) The amount of mechanical energy dissipated in the process can be calculated as E = K + (total change in angular momentum). Energy is not conserved because some of it is dissipated due to friction between the sphere and the block.
1. How does the velocity of the rolling ball affect the impact on the sphere?
The velocity of the rolling ball plays a major role in the impact on the sphere. The higher the velocity, the greater the force of impact and the more likely it is to cause the sphere to move or deform.
2. What factors besides velocity can affect the outcome of a rolling ball hitting a sphere?
Besides velocity, the mass and size of the rolling ball, as well as the material and shape of the sphere, can all affect the outcome of the impact. Other factors to consider include the angle of impact and the surface properties of both objects.
3. How does the elasticity of the materials impact the collision between the rolling ball and the sphere?
The elasticity, or ability to deform and return to its original shape, of the materials can greatly affect the collision. If both objects have high elasticity, the impact will be more elastic and the objects will bounce off each other. If one or both objects have low elasticity, the impact will be more inelastic and the objects may stick together or deform.
4. Can the trajectory of the rolling ball be predicted based on the angle of impact?
Yes, the angle of impact can be used to predict the trajectory of the rolling ball after it hits the sphere. The angle of incidence (angle at which the ball hits the sphere) will be equal to the angle of reflection (angle at which the ball bounces off the sphere) when both objects have the same elasticity.
5. How can the conservation of energy and momentum be applied to the collision between the rolling ball and the sphere?
The conservation of energy and momentum can be applied to the collision between the rolling ball and the sphere to determine the resulting velocities and directions of both objects after the impact. The total momentum and kinetic energy of the system before and after the collision should be equal, assuming there are no external forces acting on the objects.
