Shankar One-Dimensional Problem
  • Thread starter Dahaka14
  • Tags
    Shankar
Basically, if you have a continuous function f(x) on the interval [a,b], then there exists a point c in [a,b] such that the integral of f(x) from a to b is equal to (b-a)f(c). This might help you find a way to make E(\alpha) negative.
Dahaka14
73
Exercise 5.2.2 (b.)
Prove the following theorem: Every attractive potential in one dimension has at least one bound state. Hint: Since [tex]V[/tex] is attractive, if we define [tex]V(\infty)=0[/tex], it follows that [tex]V(x)=-|V(x)|[/tex] for all [tex]x[/tex]. To show that there exists a bound state with [tex]E<0[/tex], consider
[tex]\psi_{\alpha}(x)=\left(\frac{\alpha}{\pi}\right)^{1/4}\text{e}^{-\alpha x^{2}/2}[/tex]
and calculate
[tex]E(\alpha)=<\psi_{\alpha}|H|\psi_{\alpha}>,[/tex] [tex]H=-\frac{\hbar^{2}}{2m}\frac{d^{2}}{dx^{2}}-|V(x)|[/tex].
Show that [tex]E(\alpha)[/tex] can be made negative by suitable choice of [tex]\alpha[/tex]. The desired result follows from the application of the theorem approved above.
I evaluated the expectation value using the given wave function and special Hamiltonian and received a simpler equation of [tex]E=\frac{\alpha\hbar^{2}}{4m}-\int_{-\infty}^{\infty}|V(x)|\psi_{\alpha}^{2}dx[/tex]. I have no idea where to go from here.
Hmmm... You might try using the mean value theorem for integration.
Related to Shankar One-Dimensional Problem
1. What is the Shankar One-Dimensional Problem?
The Shankar One-Dimensional Problem, also known as the Shankar Model, is a simplified version of the Schrödinger equation used to describe the behavior of a single particle in one dimension. It was developed by physicist Ramamurti Shankar as a way to teach introductory quantum mechanics.
2. What is the significance of the Shankar One-Dimensional Problem?
The Shankar One-Dimensional Problem is significant because it allows for a deeper understanding of the principles of quantum mechanics, such as wave-particle duality and the quantization of energy levels. It also serves as a building block for more complex quantum mechanical systems.
3. How is the Shankar One-Dimensional Problem solved?
The Shankar One-Dimensional Problem is typically solved using mathematical techniques such as separation of variables and normalization of wavefunctions. These methods allow for the determination of the allowed energy levels and corresponding wavefunctions for a given potential energy function.
4. What are some common applications of the Shankar One-Dimensional Problem?
The Shankar One-Dimensional Problem has many applications in various fields, including atomic and molecular physics, solid state physics, and quantum computing. It is also used as a teaching tool for understanding quantum mechanical principles.
5. Are there any limitations to the Shankar One-Dimensional Problem?
Although the Shankar One-Dimensional Problem is a useful model for understanding basic principles of quantum mechanics, it has limitations. It only applies to systems with one particle in one dimension, and it does not take into account the effects of relativity or interactions between particles. More complex models are needed to describe these systems.
